1 Reply Latest reply on Jul 24, 2008 11:56 AM by webacity
    Drag and Drop question - limit to number of entries
    webacity
      looks like the drag and drop question slide has a limit to the number of entries in column 1.
      8 entries to be precise.
      That's ok for me in this case, as my example has 8 entries for column 1. However when you run the application, it seems it will only shows 6 entries in column 1. I tried to look for the missing 2, hoping they might be hidden or slightly off screen somewhere. Has anyone encountered this problem?
        • 1. Re: Drag and Drop question - limit to number of entries
          webacity Level 1
          This is interesting. As well as having the above problem, I was getting an incorrect result when dragging to the correct points in column 2. even though it should be correct
          Because of the issue in the previous post, i.e. not being able to see the last two entries, I decided to delete them.
          Hey presto this seemed to fix this above problem. Now my drag and drop works.
          It seems captivate doesn't like to go beyond 6 entries in column 1 i.e. doesn't show the extra entries and also causes an false error when successfully completing the drag and drop
