2 Replies Latest reply on Nov 2, 2009 8:19 PM by Eliot Harper
    InDesign CS4 Server serialisation
    Cari Jansen Adobe Community Professional
      Hi guys,
      I'm installing a InDesign CS4 Server on Windows 2003 Server for Small Business Server, Service Pack 2. 4Gb available on C:drive,Intel Xeon 3.2Ghz, 4Gb Ram
      The machine had InDesign CS3 Server installed previously.
      1. Uninstalled InDesign CS3 Server
      2. Rebooted Machine.
      3. Installed CS4 Server
      4. Installed latest Rapid Release
      5. Setup Win Service
      and wondered why I wasn't prompted for the serial number at start of install. (ok, I hear you... should have read the read-me file first to see if anything in the installation process had changed...).
      So I stopped the ID-Service and then ran the command-line serialisation at this point.
      Checked in TaskManager no ID Server was running.
      However the serialisation hangs after:
      <pre>
      08/26/09 10:15:05 INFO  [server] Server Runnin/g
      </pre>
      And the serialisation process seems to launch two processes at this stage: InDesignServer.com and InDesignServer.exe.
      Which is right before this step... which is repeated twice and then the cursor just sits there... (doing nothing).
      <pre>
      [javascript] Executing File: C:\Program Files\Adobe\Adob
      e InDesign CS4 Server\Scripts\Export As XHTML\XHTMLExportMenuItem.jsxbin
      </pre>
      Before back-tracking fully and doing a complete uninstall and reinstall (and this time serialising after step 3), I thought I'd check if anyone had come across this and has a possible clue as to what's going in.  Any help appreciated.
      At this stage I'm scheduling a full uninstall/reinstall for Thursday if things aren't resolved today (Wednesday).
      Cari
      Snr Solutions Consultant,
      Typefi Systems.
      Here's what I see in the cmd console:
      <pre>
      Microsoft Windows [Version 5.2.3790]
      (C) Copyright 1985-2003 Microsoft Corp.
      C:\Program Files\Adobe\Adobe InDesign CS4 Server>indesignserver -serialnumber xx
      xx-xxxx-xxxx-xxxx-xxxx-xxxx
      .  Version 6.0.4
      .  Adobe, the Adobe logo, InDesign, and InCopy are either registered trademarks
      .  or trademarks of Adobe Systems Incorporated in the United States and/or other
      .  etc.
      08/26/09 10:14:58 INFO  [server] Initialising
      08/26/09 10:14:58 INFO  [server] Loading the application
      08/26/09 10:14:58 INFO  [server] Restoring Object Model
      08/26/09 10:14:58 INFO  [server] Scanning for plug-ins
      08/26/09 10:14:58 INFO  [server] Initialising plug-ins
      08/26/09 10:14:58 INFO  [server] Starting up Service Registry
      08/26/09 10:15:03 INFO  [server] Executing startup services
      08/26/09 10:15:03 INFO  [server] Using configuration configuration_noport
      08/26/09 10:15:05 INFO  [server] Initialising the SING gaiji system
      08/26/09 10:15:05 INFO  [server] Initialising Application
      08/26/09 10:15:05 INFO  [server] Completing Initialisation
      08/26/09 10:15:05 INFO  [server] Image previews are off
      08/26/09 10:15:05 INFO  [server] Server Running
      08/26/09 10:15:05 INFO  [javascript] Executing File: C:\Program Files\Adobe\Adob
      e InDesign CS4 Server\Scripts\Export As XHTML\startup scripts\XHTMLExportMenuIte
      mLoader.jsx
      </pre>
        • 1. Re: InDesign CS4 Server serialisation
          BrendanOShea
          That looks correct - InDesignServer is up & running, waiting for commands, or a control-c to quit.
          InDesignServer.com is a shell app which launches InDesignServer.exe, so having both processes active is correct.
          Once you have successfully serialized (as it appears you have), you should be able to restart either via the Windows service or at the command line without the '-serialnumber' parameter.
          -Brendan O'Shea
          InDesignServer Engineering
          • 2. Re: InDesign CS4 Server serialisation
            Eliot Harper Level 1
            Thanks Brendan, I hit the same issue. It appears that the command line script hasn't completed as it just stops on the last line that Cari noted and doesn't display the command prompt, but InDesign Server runs fine after restarting the Windows service.
            Eliot
            www.eliot.com.au
