3 Replies Latest reply on Aug 26, 2009 9:02 AM by Barna Biro
    Re:Item renderer AS3 for datagrid
    Venkat,Flex Developer
      I am having a data grid with multiple check boxes for this i am using CheckCellRendererEdit as itemrenderer.When i am making a change in datagrid checkbox its not updating
      The problems are
      1. when i select a checkbox in second row it gets selected in another  row after saving
      2.when i choose one checkbox in a row it gets afftected in many row can i get a solution for this Below given is the code i am using
      CheckCellRendererEdit.as
      package
          import mx.controls.*;
      import mx.core.*;
      import mx.controls.dataGridClasses.DataGridListData;
      import flash.events.Event;
      import flash.events.MouseEvent;
      public class CheckCellRendererEdit extends CheckBox
      // Define the constructor and set properties.
      public function CheckCellRendererEdit() {
          super();
      override protected function clickHandler(event:MouseEvent):void
                  if (!enabled)
                  {    //DataGrid(this.parentDocument.dg).selectedItem.vdata=CheckBox(event.currentTarget).selec ted;
                          event.stopImmediatePropagation();
                          return;
                  if (toggle)
                      selected = !selected;
        • 1. Re:Item renderer AS3 for datagrid
          Barna Biro Level 3
          Take a look at this: http://blog.wisebisoft.com/2009/05/09/working-with-item-renderers/ Your renderers are being reused and if you don't override certain methods that will "force" the update each time the data changes then the change won't be reflected immediately.
          • 2. Re:Item renderer AS3 for datagrid
            Venkat,Flex Developer Level 1
            Currently i am migrating from flex1.5 to flex2 Just i am using this itemrenderer(checkbox) for DataGrid can i have some ideas for datagrid
            The DataGrid i am using is
            <mx:DataGrid id="screendg" ">
                        <mx:columns>
                          <mx:Array>
                            <mx:DataGridColumn headerText="mdata" dataField="screenid" editable="false" />
                            <mx:DataGridColumn headerText="data" dataField="mdata" itemRenderer="CheckCellRendererEdit"  />
                            <mx:DataGridColumn headerText="mdata" dataField="vdata" itemRenderer="CheckCellRendererEdit"  />
                            <mx:DataGridColumn headerText="cdata" dataField="cdata" itemRenderer="CheckCellRendererEdit"  />
                            <mx:DataGridColumn headerText="vdata" dataField="udata" itemRenderer="CheckCellRendererEdit"  />
                        </mx:Array>
                        </mx:columns>
                      </mx:DataGrid>
            When i am selecting a checkbox in data grid the grid value is not getting changed
            • 3. Re:Item renderer AS3 for datagrid
              Barna Biro Level 3
              An item renderer is an item renderer, no matter if it's set to a DataGrid, a List or whatever. It work the same way for all the components. If you'll take the time to read and understand the example I just linked you to then you should be able to manage.
