4 Replies Latest reply on Aug 28, 2009 11:17 PM by Venkat,Flex Developer
    Flex-2 ItemRenderer
      In flex 2 i am using this code for itemrenderer if i select a checkbox in datagridand when i scroll the grid many nonselected checkbox are getting selected how can i solve this problem
      <mx:DataGridColumn headerText="Update" dataField="udata" >
                      <mx:itemRenderer>
                               <mx:Component>
                                   <mx:CheckBox selectedField="udata" change="data.udata = selected" />
                               </mx:Component>
                           </mx:itemRenderer>
                      </mx:DataGridColumn>
      Thanks in advance.
        • 1. Re: Flex-2 ItemRenderer
          Andrew Rosewarn Level 3
          Hi Ventak
          Yea I found this a pain but this should work for you, example below, hope it helps.
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"  xmlns:ns1="*">
          <mx:Script>
          <![CDATA[
          import mx.collections.ArrayCollection;
          [Bindable]
          private var ac:ArrayCollection = new ArrayCollection([
          {theName : 'Test 0', answer : true},
          {theName : 'Test 1', answer : false},
          {theName : 'Test 2', answer : false},
          {theName : 'Test 3', answer : true},
          {theName : 'Test 4', answer : false},
          {theName : 'test 5', answer : false},
          {theName : 'Test 6', answer : true},
          {theName : 'Test 7', answer : false},
          {theName : 'Test 8', answer : false},
          {theName : 'Test 9', answer : true},
          {theName : 'Test 10', answer : false}
          </mx:Script>
          <mx:DataGrid x="251" y="178" dataProvider="{ac}">
          <mx:columns>
          <mx:DataGridColumn headerText="Column 1" dataField="theName"/>
          <mx:DataGridColumn headerText="Column 2" dataField="answer">
            <mx:itemRenderer>
                <mx:Component>
                   <mx:CheckBox click="{data.answer=!data.answer}"  selected="{data.answer}"/>
                </mx:Component>
             </mx:itemRenderer>
          </mx:columns>
          </mx:DataGrid>
          </mx:Application>
          • 2. Re: Flex-2 ItemRenderer
            christopher.mina Level 1
            To be more certain about it, you can also use the syntax:
            <mx:Component>
            <mx:Checkbox selected="{data.answer}" change="data.answer = this.selected"/>
            </mx:Component>
            Here I'm using the actual selection property of the checkbox to set the answer, so we're confident the user is always seeing the correct outcome.  They both work fine, though.
            • 3. Re: Flex-2 ItemRenderer
              ShardulSingh Level 3
              Pls find the soution of your problem.
              I am using two Datagrid on the selection of any checkbox, I am showing that in the another one.
              Pls let me know if you have any issue.
              MainApplication.mxml
                <?xml version="1.0"?>
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
              <mx:Script>
                  <![CDATA[
                      import mx.events.ListEvent;
                          [Bindable]
                          private var docDetailAC:ArrayCollection = new ArrayCollection([
                              {chkBoxValue:false,srNo:'1',docName:'Employee Details'},
                              {chkBoxValue:false,srNo:'2',docName:'Busines Policies'},
                              {chkBoxValue:false,srNo:'3',docName:'Tax Policies'}
                          [Bindable]
                          private var acCopy : ArrayCollection = new ArrayCollection();
                          private function onItemClick(event : ListEvent):void
                              if(event.itemRenderer is CheckBoxItemRenderer)
                                  var currentIndex : Number = event.rowIndex;
                                  if(acCopy.length > 0)
                                      acCopy.removeAll();
                                      acCopy.refresh();
                                      for (var i:Number = 0;i < docDetailAC.length;i++)
                                          if(i == currentIndex)
                                              docDetailAC[i].chkBoxValue = true;
                                          else
                                              docDetailAC[i].chkBoxValue = false;
                                          docDetailGrid.invalidateList();
                                  var acItem : Object = docDetailAC.getItemAt(currentIndex);
                                  acCopy.addItem(acItem);
              </mx:Script>
                  <mx:Panel height="100%" width="100%"
                      paddingTop="10" paddingLeft="10" paddingRight="10">
                      <mx:Label width="100%" color="black"
                          text="Select a row in the DataGrid control."/>
                     <mx:DataGrid width="300" height="150" id="docDetailGrid"
                              dataProvider="{docDetailAC}"
                              editable="true"
                              horizontalScrollPolicy="off"
                              itemClick="onItemClick(event)">
                              <mx:columns>
                                  <mx:DataGridColumn id="docDetailDG_1" headerText="No" width="40" editable="false"
                                      itemRenderer="CheckBoxItemRenderer" />
                                  <mx:DataGridColumn headerText="No" width="40" dataField="srNo" editable="false"/>
                                  <mx:DataGridColumn headerText="Doc Name" dataField="docName" />
                              </mx:columns>
                          </mx:DataGrid>
                      <mx:Label width="100%" color="red"
                          text="Selected item in the DataGrid control."/>
                                                  dataProvider="{acCopy}"
                                                  horizontalScrollPolicy="off">
                                                  <mx:columns>
                                                      <mx:DataGridColumn  headerText="Document Name " dataField="docName" />
                                                  </mx:columns>
                                              </mx:DataGrid>
                  </mx:Panel>
              </mx:Application>
              CheckBoxItemRenderer.mxml
              <mx:HBox xmlns:mx="http://www.adobe.com/2006/mxml"
                  horizontalAlign="center" verticalAlign="middle">
                  <mx:Script>
                      <![CDATA[
                          override public function set data(value:Object):void
                              super.data = value;
                          private function onCheckBoxClick():void
                              this.data.chkBoxValue = true;
                  </mx:Script>
                  <mx:Spacer width="1" />
                  <mx:CheckBox click="onCheckBoxClick()" selected="{data.chkBoxValue}"/>
              </mx:HBox>
              with  Regards,
              Shardul Singh Bartwal
              • 4. Re: Flex-2 ItemRenderer
                Venkat,Flex Developer Level 1
                Thans for your replay really it works
