2 Replies Latest reply on Aug 26, 2009 5:49 AM by Niranjan_swain
    Grouping issue on Advanced DataGrid
    nickmiddleweek
      Hello,
      I've got an advanced datagrid with 5 columns, The number_Group column has data like this...
      1-10
      1-10
      11-20
      11-20
      11-20
      21-30
      21-30
      21-30
      41-50
      101-110
      When I apply Grouping, it works as expected but the 101-110 group is displayed before the 11-20 group.
      I've tried to set groupingField.numeric = true but that screws it up even more... because 11-20 isn't a number I'm guessing.
      Does anyone know a way around this? I could change the number_Group column to this...
      1
      1
      11
      11
      21
      41
      101
      and groupingField.numeric = true should work but I need the Grouping display to show 1-10, 11-20. Perhaps I can intercept this and modify it?
      Anyone got any ideas?
      Nick
        • 1. Re: Grouping issue on Advanced DataGrid
          nickmiddleweek Level 1
          Answer = use GroupingField.groupingFunction :-)
          Does anyone know what the groupingObjectFunction does? What is the returned Object for?
          Nick
          • 2. Re: Grouping issue on Advanced DataGrid
            Niranjan_swain
            Hi, Nicky
            u can solve this problem by grouping function.
            u create ur dataprovider like
            private var myData:ArrayCollection = new  ArrayCollection([{data1:1, data2:10,......},
        {data1:1, data2:21, ....}]);
            u declare the grouping function in following manner
            private function myGroupLabelFunction(item:Object, column:AdvancedDataGridColumn):String
            // here u write ur logice to formatting ur dispalying data in advance grid.
            //suppose ur labelfield of datagrid are data1,data2, data3 respectively.
            return item.data1+"-"+item.data2;
            if u do in this way i think it will work.
            if u sucess then give me mark.
            Niranjan
