0 Replies Latest reply on Aug 26, 2009 4:38 AM by Carol L. Frampton
    [svn:fx-trunk] 9615: TLF main Build 502
    Carol L. Frampton Level 2
      Revision: 9615
      Author:   cframpto@adobe.com
      Date:     2009-08-26 04:38:22 -0700 (Wed, 26 Aug 2009)
      Log Message:
      TLF main Build 502
      This build includes a fix for editing right-to-left text that is needed for our DataGrid demo with rtl text.
      QE notes: TextArea, TextInput and NumericStepper tests with selections and insertion pts break because they look slightly taller
      Doc notes:
      Bugs:
      Reviewer: ok from Gordon
      Tests run: TextArea, TextInput and NumericStepper
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/BaseTextLayoutImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/HtmlImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/TextConverter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/TextLayoutImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/Build Info.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/BaseCompose.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/ComposeState.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/IFlowComposer.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/ParcelList.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/StandardFlowComposer.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/TextFlowLine.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/conta iner/ContainerController.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/FlowGroupElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/LinkElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/SpanElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/SubParagraphGroupElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/facto ry/StringTextLineFactory.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/facto ry/TextFlowTextLineFactory.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/conta iner/TextContainerManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ EditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ IEditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ SelectionManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ TextClipboard.as
          flex/sdk/trunk/frameworks/projects/textLayout/tlf.properties
