1 Reply Latest reply on Aug 26, 2009 6:55 AM by Roaders
    Running more than 1 flexunit task per ant build
    Roaders Level 1
      Hi
      I am setting our ant build up to run our unit tests. I have a macrodef that compiels and runs the tests:
      <macrodef name="runTests" >
      <attribute name="runner" />
      <attribute name="outputName" />
      <attribute name="sourceLocation" />
      <sequential>
      <mxmlc file="@{runner}" output="${REPORT.dir}/@{outputName}.swf">
      <source-path path-element="@{sourceLocation}" />
      <library-path dir="${LIBS.dir}" append="true">
      <include name="*.swc" />
      </library-path>
      <library-path dir="${DEPLOY_BIN.dir}" append="true">
      </library-path>
      </mxmlc>
      <!-- Execute TestRunner.swf as FlexUnit tests and publish reports -->
      <flexunit
      swf="${REPORT.dir}/@{outputName}.swf"
      toDir="${REPORT.dir}/xml"
      haltonfailure="false"
      verbose="true"
      localTrusted="true"
      </sequential>
      </macrodef>
      and a task that calls this multiple times, builds the reports and then fails if any of the tests failed:
      <target name="compileTools">
      <antcall target="compileDevToolsModule"/>
      </target>
      <target name="runUnitTests" depends="compileLibs">
      <antcall target="compileCoreTest" />
      <runTests
      runner="${CORE_TESTS_PROJECT.dir}/src/CoreTests.mxml"
      outputName="core"
      sourceLocation="${CORE_TESTS_PROJECT.dir}/src"
      <runTests
      runner="${LOGIN_PROJECT.dir}/src/LoginTests.mxml"
      outputName="login"
      sourceLocation="${LOGIN_PROJECT.dir}/test"
      <antcall target="buildReports"/>
      <fail if="flexunit.failed" message="Unit Tests Failed. Check reports." />
      </target>
      Thsi all works fine if I am only running one test runner. If I am running 2 as in teh above example the second swf opens and all the tests run but it does not close. If I manually close it the ant build continues but no xml files are produced for the second runner.
      The reason I am running the tasks like this is because we have a lot of projects that each create a module. We can't have 1 test runner that runs all tests (unless we have test modules and load the tests into a main test runner ect but that's annoying).
      Is this scenario supported?
