11 Replies Latest reply on Dec 20, 2009 5:40 PM by the_wine_snob
    media encoder status error CS4
    Andy Wason Level 1
      I cant get my CS4 projects to encode!
      Media encoder gives me a status error. (yellow triangle in the status column) When I open the text file I get:
      - Source File: C:\Users\Andrew\AppData\Local\Temp\denis final CS4_1.prproj
      - Output File: E:\Sequence 01.wav
      - Preset Used: Windows Waveform 48kHz 16-bit
      - Video:
      - Audio:
      - Bitrate:
      - Encoding Time: 649:51:33
      8/25/2009 9:10:49 AM : Encoding Failed
      Could not read from the source. Please check if it has moved or been deleted.
      Other info:
      -Vista 64bit,
      -Adobe creative Suite CS4. Premiere CS4 4.1.0
      -It wont encode anything, I've tried a few projects, the above one was an export of audio timeline.
      -The project "denis final CS4.prproj" is actually in my "E:" drive
      -A renamed project called "denis final CS4_1.prproj" (created by CS4 I assume) does in fact exist in "C:\Users\Andrew\AppData\Local\Temp\"
      -I am unable to deactivate  Premiere CS4 . It allows me to deactivate successfully, but comes up active next time I run.
      Any ideas?
      thanks,
      Andy
