3 Replies Latest reply on May 23, 2012 11:12 PM by Shripad_joshi
    OLAPResult as a dataprovider for AdvancedDataGrid cat it be?
    m-r-m-2-0-9-0
      Hi all,
      Is there a way to convert OLAPDataGrid to AdvancedDataGrid?
      I wonder if it is possible to build a dynamic ArrayCollection based on an OLAPResult object? I need to represent a result from an OLAP query into an ArrayCollection or anything else that can be used as a dataprovider for AdvancedDataGrid.
      If possible, does anyone have any idea on how to?
      Any comment is welcommed..
        • 1. Re: OLAPResult as a dataprovider for AdvancedDataGrid cat it be?
          cjolif-Fc6gNO
          What about using OLAPDataGrid instead of ADG?
          Christophe
          m-r-m-2-0-9-0 <forums@adobe.com>
          To:
          Christophe Jolif/France/IBM@IBMFR
          Date:
          08/26/2009 03:18 PM
          Subject:
          it be?
          Hi all,
          AdvancedDataGrid.
          • 2. Re: OLAPResult as a dataprovider for AdvancedDataGrid cat it be?
            m-r-m-2-0-9-0 Level 1
            Hi Christophe,
            thank u for the reply..
            I want to use ADG to show OLAP data as simple table (i.e. no drill up no drill down .. etc) so I can benefit from features of ADG like sorting, moving columns etc.
            are such features implemntable by ODG?
            thankx again
            mrm
            • 3. Re: OLAPResult as a dataprovider for AdvancedDataGrid cat it be?
              Shripad_joshi
              Hi all,
              I am also looking for the same technique you need to implement for your problem. I just found a method to convert the OLAP Result into arrayCollection...
              hope this may help you..
              private function onCubeQueryResult(event:Object, token:Object):void                              {
                                                      var tempCubeData:OLAPResult = event as OLAPResult;
                                                      if (!(tempCubeData is OLAPResult))
        return;
                                                      var colAxis:IOLAPQueryAxis = tempCubeData.query.getAxis(OLAPQuery.COLUMN_AXIS);
                                                      var columnLength:Number = tempCubeData.getAxis(OLAPQuery.COLUMN_AXIS).positions.length;
                                                      var rowAxis:IOLAPQueryAxis = tempCubeData.query.getAxis(OLAPQuery.ROW_AXIS);
                                                      var rowLength:Number = tempCubeData.getAxis(OLAPQuery.ROW_AXIS).positions.length;
                                                      var newChartData:Array = [];
                                                      for(var j:int = 0; j < rowLength; j++) {
        for (var i:int=0;i<columnLength;i++) {
        var tuple:OLAPTuple = colAxis.tuples[i];
        var key:String = tuple.explicitMembers.toArray().join(",");
        if (key.indexOf("(All)") > -1) continue;
        newChartData.push({key:key, value:tempCubeData.getCell(j, i).value});
              var chartData:ArrayCollection = new ArrayCollection(newChartData);
