6 Replies Latest reply on Sep 2, 2009 8:45 AM by tictacmoose1
    [AS] Trying to change Single Record number under data merge?
    tictacmoose1
      Any help would be great?
        • 1. Re: [AS] Trying to change Single Record number under data merge?
          wreyfmonkey
          Hi tictacmoose1,
          Can you be more specific about what exactly you are trying to do?  Are you talking about changing some of the data merge properties?
          • 2. Re: [AS] Trying to change Single Record number under data merge?
            tictacmoose1 Level 1
            Sorry for the lack of explanation.  I'm trying to edit the menu in data merge.  So far, I am able to edit the data merge options, but I can't edit the data merge properties or preferences.  For example, the following script works great:
            tell application "Adobe InDesign CS3"
            tell data merge options of document 1
            set fitting option to proportional
            set center image to true
            set link images to true
            set remove blank lines to false
            set document size to 1
            end tell
            end tell
            But what I have been unable to do is something like this:
            tell data merge properties  of document 1
            set record selection to all records
            set records per page to single record
            end tell
            end tell
            I get the error: "Adobe InDesign CS3 got an error: Can’t set record selection of data merge properties of document 1 to all records."  So I'm wondering how in the world I can change that "record selection" and "records per page" property to that my users don't have to interact with it directly.  I'm sure it can be done, but it appears it is beyond me!  Any help is greatly appreciated.  Thanks in advance!
            • 3. Re: [AS] Trying to change Single Record number under data merge?
              zeRafio Level 1
              try this:
              tell data merge preferences
              end tell
              • 4. Re: [AS] Trying to change Single Record number under data merge?
                wreyfmonkey Level 1
                That was worth a try, zeRafio, but your script errors for me.  Did it not error for you when you tried it?  I also changed it to "data merge preferences of document 1" with the same result:
                Adobe InDesign CS3 got an error: Can’t set record selection of data merge preferences to all records.
                • 5. Re: [AS] Trying to change Single Record number under data merge?
                  zeRafio Level 1
                  tell data merge 1 of document 1
                  end tell
                  end tell
                  end tell
                  • 6. Re: [AS] Trying to change Single Record number under data merge?
                    This is where I am trying to go with this:
                    set record number to 3--or any number or i value I want to repeat with
                    end tell
                    end tell
                    tell document 1
                    tell data merge properties to merge records--and merge that one number
                    end tell
                    end tell
                    Setting the record number actually changes the field for single record but when I try to merge said number it does all the records. I am sure its an ordering thing but it is still causing some head scratches. You've all been really helpful with an area that doesnt seem to be detailed anywhere.
                    Any help would be great. Thanks.
