Hello all the freinds
I try to capture an elearning with my adobe captivate cs4 and it realy works very nice ,but I can't pause my simulation ,when I press PAUSE key ,it doesn't pause the simulatin ,but the End key works and end the simulation ,
would you please help me
I appreciate you
Hi there
Are you talking about trying to pause playback of a recorded demonstration? For example, you recorded a series of steps, you are playing it back and you are trying to press Pause to stop playback?
Pause is intended to suspend the recording process. Perhaps you began recording a series of steps, a window popped up unexpectedly, so you press Pause so Captivate doesn't record your action of dealing with the sudden new window. You deal with it, press Pause again and resume your recording.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Hello and thank you very much for your attention
I press pause key to suspend the recording process ,but it doesn't suspend the recording and it continues to record ,that's my problem.
Sincerely yours Mohsena
I seem to encounter the same problem too. The pause button seems to work, but when I preview the recording, the playback skips the slide which I used the pause button.
Would be most grateful if someone could help with this problem please.
Many thanks.
I seem to have the same problem dealing with the pause function. I decided to just deal with whatever unexpectedly happened and edit it out later -> But it'd really save me time if it'd work properly.
Like said before; it just skips the "slide" I was recording while the unexpected happened, practically requiring me to re-do the recording. I'm expecting this to be a bug, I'll report it as a bug at the end of the week if we don't find a solution to it
Hi there
Perhaps try tapping the Print Screen key just before pressing Pause? My hope is that it would sort of "Finalize" the slide being missed and grab another slide you could easily discard later.
Cheers... Rick
Hi Rick, many thanks for your suggestion. I shall try it out.
Thanks again.
