3 Replies Latest reply on Aug 26, 2009 12:58 PM by PropWash
    Label properties and custom class
    PropWash
      I want to make the following persistent: <mx:Label useHandCursor="true" buttonMode="true" mouseChildren="false" />
      I have tried to create a custom class that extends the Label class, but can't get the syntax right.
      override protected ???
      buttonMode=true;
      I don't think that I want to override a function.  It seems to me that I want to override a property or attribute of the Label class.
      Can anyone give me any guidance?
        • 1. Re: Label properties and custom class
          Virat Patel
          Hi
          As you need Lable with default property {  useHandCursor="true" buttonMode="true" mouseChildren="false" }
          I have extend the Label you can do it in directly in constructor by setting the value
          ------------- Custom Label Class ----------------------------------
          package
              import mx.controls.Label;
              public class CusLbl extends Label
                  public function CusLbl()
                      super();
                      super.buttonMode = true;
                      super.useHandCursor = true;
                      super.mouseChildren = false;
          You can directly use in application or in any other container with default property;
          Ckeck attached file if needed.
          With Regards
          Virat Patel
          • 2. Re: Label properties and custom class
            PropWash Level 1
            That works perfectly!  Thank you very much!
            • 3. Re: Label properties and custom class
              PropWash Level 1
              Virat,
              Your solution worked perfectly.  Thank you very much.  I appreciate your prompt response and help.
              Gary
