3 Replies Latest reply on Aug 27, 2009 12:28 PM by wolfman33
    How to populate a tree from .aspx file?
    starbabu
      I'm very new to flex. I have a .aspx file which has xml populated in it. I would like to populate the tree based on the values of the .aspx file. Here is my code which i have tried doing this functionality but it couldn't worked out. Could anyone help me out to resolve this problem.
      This is my sample aspx file:
      Sample.aspx:
      <myTree label="Main Root">
      <node label="Root">
      <node label="Folder a">
      <node label="item 1 a"/>
      </node>
      <node label="Folder b">
      <node label="item 1 b"/>
      <node label="item 2 b"/>
      </node>
      <node label="Folder c">
      <node label="item 1 c"/>
      <node label="item 2 c"/>
      </node>
      <node label="Folder d">
      <node label="item 1 d"/>
      <node label="item 2 d"/>
      </node>
      </node>
      </myTree>
      Here is my mxml file which i was trying:
      TreefromXml.mxml:
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="XmlRpc.send()"
      <mx:Script>
      <![CDATA[
      import
      mx.collections.ArrayCollection;
      import
      mx.rpc.events.FaultEvent;
      import
      mx.rpc.events.ResultEvent;
      import
      mx.controls.Alert;
      public var XmlNode:XML=new
      XML();
      public function HandleXml(event:ResultEvent):
      void
      XmlNode= new XML(event.result.myTree.node);
      tree1.dataProvider=event.result.myTree.node;
      public function HandleFault(event:FaultEvent):
      void
      Alert.show(event.fault.faultString, "Error"
      </mx:Script>
      <mx:HTTPService id="XmlRpc" url="Sample.aspx" result="HandleXml(event)" fault="HandleFault(event)">
      </mx:HTTPService>
      <mx:Panel id="panel1" width="400" height="200">
      <mx:Label id="label1" text="Sample Label" />
      <mx:Tree id="tree1" labelField="@label">
      </mx:Tree>
      </mx:Panel>
