1 Reply Latest reply on Sep 28, 2009 10:13 PM by souldreamer
    Affect Pixels Bolow 0.0 only
    JorritS
      hi, im am working on this Quite simple Plugin, but now i ran into This Problem
      i have this High contrast filter, but i only want the Bright pixels to get higher the dark pixels of "AP" to be 0
      Here's the code:
              parameter float Amount
              minValue:1.0;
              maxValue:10.0;
              defaultValue:1.0;
              aeUIControl:"aeSlider";
              aeDisplayName: "Amount (1.0=)";
          input image4 src;
          output pixel4 dst;
          void
          evaluatePixel()
              pixel4 OP = sampleNearest(src,outCoord());
              pixel4 AP = sampleNearest(src,outCoord());
              AP.rgb = (AP.rgb - 0.75)/(1.0 - 0.75);
              dst = OP + (AP*(Amount - 1.0));
      so i basicly need the pixels from "AP" that are lower than 0.0 to be 0.0
      Thanks in Advanced
        • 1. Re: Affect Pixels Bolow 0.0 only
          souldreamer
          Just use
          float lessThan0 = 1.0 - float(any(lessThan(float3_vector_here, float3(0.0, 0.0, 0.0))));
          Though it's kind of rough like this, so some smoothing should be implemented.
          If I understood what you wanted correctly, then the change to your code would be to replace the dst = OP+... line with:
                  float lessThan0 = 1.0 - float(any(lessThan(AP.rgb, float3(0.0, 0.0, 0.0))));
                  float4 Add = AP*(Amount - 1.0)*lessThan0; Add.a = AP.a;
                  dst = OP+Add;
