4 Replies Latest reply on Aug 26, 2009 9:23 PM by Flex harUI
    textArea inside HorizontalList
    Luke Immes Level 1
      HorizontalList works with label="my text"...
      I want it to work with TextArea information, it shows: TextArea TextArea ....
      Aside: DataGrid displays long labels with word wrap- which is fine, assuming I use columns.
      So, to reiterate, 'How  can I get textArea, with optional word wrap in a horizontal list?
      Thanks for your time.
      LPImmes.
      <mx:VBox height="100%">
      <mx:HorizontalList alternatingItemColors="[#ffffff, #cccccc]" dragEnabled="true" dropEnabled="true" dragMoveEnabled="true"
      borderColor="#67D7BE" borderStyle="solid" borderThickness="10" height="150" toolTip="START: Drag/drop item to any other box."
      <!--<mx:columns>
      <mx:DataGridColumn headerText="RECMDED BLOGS" wordWrap="true" width="125" dataField="title"/>
      </mx:columns>-->
      <!-- DataGrid data -->
      <!--<mx:dataProvider>
      <mx:ArrayCollection>
      <mx:Object blogId="0" title="Cafferty File: Tell Jack how you really feel Blog Archive - If N ..." />
      <mx:Object blogId="1" title="CNN Political Ticker: All politics, all the time Blog Archive ..." />
      <mx:Object blogId="2" title="Cafferty File: Tell Jack how you really feel Blog Archive - North ..." />
      <mx:Object blogId="3" title="Palin's Charlie Gibson Debut - The Stump" />
      <mx:Object blogId="4" title="Ben Smith&#39;s Blog: Obama: &#39;Steel in his spine&#39; - Politico.com" />
      </mx:ArrayCollection>
      </mx:dataProvider>-->
      <!-- HorizontalList data, works with HorizontalList, but text is spread out in FULL. I don't want this. -->
      <mx:dataProvider>
      <mx:TextArea text="Cafferty File: Tell Jack how you really feel Blog Archive - If N ..."/>
      <mx:TextArea text="Cafferty File: Tell Jack how you really feel Blog Archive - If N ..." />
      <mx:TextArea text="CNN Political Ticker: All politics, all the time Blog Archive ..." />
      <mx:TextArea text="Cafferty File: Tell Jack how you really feel Blog Archive - North ..." />
      <mx:TextArea text="Palin's Charlie Gibson Debut - The Stump" />
      <mx:TextArea text="Ben Smith&#39;s Blog: Obama: &#39;Steel in his spine&#39; - Politico.com" />
      </mx:dataProvider>
      </mx:HorizontalList>
      </mx:VBox>
        • 1. Re: textArea inside HorizontalList
          Luke Immes Level 1
          From LPImmes,
          Test reply; I should get some email.
          Luke
          • 2. Re: textArea inside HorizontalList
            Flex harUI Adobe Employee
            I'm not clear on the problem.  If you set the itemRenderer=TextArea, what do you get?
            Alex Harui
            Flex SDK Developer
            Adobe Systems Inc.
            Blog: http://blogs.adobe.com/aharui
            • 3. Re: textArea inside HorizontalList
              Luke Immes Level 1
              Goal, that I want to achieve, i.e., the WHAT, not the HOW:
              First textArea has text and we          Second text area is now being filled           We are in a horizontal          This row should be
              write more. Boxes are OK                 and it wraps around.                                  row 0; 3rd textarea              scrollable individual
              around the text area        text areas; 4th textArea.
              Size of larger container is too small to contain all text areas, so we horizontally scroll.
              TextArea, per se, need not be a text area, just something that wraps around, e.g. a label.
              Now, using dataGrid, with single column (in code, commented), I get wrapped text that is a single line. We scroll the n individual lines,
              if data grid box is too small.  This is fine, and works, but my client wants the above.
              Thanks.
              • 4. Re: textArea inside HorizontalList
                Hard to tell since the formatting seemed broken, but what did you get when you used TextArea as an itemRenderer?
                <mx:HorizontalList>
                     <mx:itemRenderer>
                          <mx:TextArea width="200" height="100" />
                Alex Harui
                Flex SDK Developer
                Adobe Systems Inc.
