6 Replies Latest reply on Aug 27, 2009 3:56 AM by flex2008
    Retrieving image path from xml file for images
    shaylee tan
      Hi. I have created a xml file which stores all the image path. How am i supposed to retrieve the image path from the xml file and display for my images?
      Currently i am hardcoding the image path for the images.Can anyone tell me how to retrieve the images from my xml file? Thanks for the help
      <mx:Image id="test" x="480" y="177" width="100" height="100" source="assets/card_2.JPG" scaleContent="false" click="test.source = 'assets/torres.JPEG';setTotalClicks();"/>
      <mx:Image id="tests" x="623" y="438" width="100" height="100" source="assets/card_2.JPG" scaleContent="false" click="tests.source = 'assets/torres.JPEG';setTotalClicks();"/>
        <memoryCards id="Soccer players">
         <memory>
          <card>
            <name>Torres</name>
            <url>assets/torres.jpg</url>
          </card>
          </memory>
          </memory>
          <memory>
          <card>
            <name>Lampard</name>
            <url>assets/lamps.jpg</url>
          </card>
          </memory>
          <memory>
          <card>
            <name>Gerrard</name>
            <url>assets/ger.jpg</url>
          </card>
          </memory>
          <memory>
          <card>
            <name>Arshavin</name>
            <url>assets/ars.jpg</url>
          </card>
          </memory>
          <memory>
          <card>
            <name>Pato</name>
            <url>assets/pat.jpg</url>
          </card>
          </memory>
          <memory>
          <card>
            <name>Kaka</name>
            <url>assets/kaka.jpg</url>
          </card>
          </memory>
         <memory>
         <card>
         <name>Vidic</name>
            <url>assets/vidic.jpg</url>
          </card>
          </memory>
          <memory>
          <card>
         <name>Ronaldo</name>
            <url>assets/ron.jpg</url>
          </card>
          </memory>
      </memoryCards>
        • 1. Re: Retrieving image path from xml file for images
          Niranjan_swain
          Hi, shaylee tan
          when u want to assign image to ur image dynamically at that time u retrive the image path from ur xml file.
          before that this image should be in ur project and the path name should be correct.
          try to use relative path it is more appropiate and work perfectily in all case.
          i give a example below i think this will help u.
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init()">
          <mx:Script>
          <![CDATA[
          private var path:String = "assets/open.gif";
          private function init():void
          myImage.source = path;
          </mx:Script>
          <mx:Image id="myImage" x="105" y="66"  width="57" height="29"/>
          </mx:Application>
          if u get sucess then give me mark
          niranjan
          • 2. Re: Retrieving image path from xml file for images
            shaylee tan Level 1
            Hi Niranja. I understand by what you meant. However, if i want to have more than 1 images in the application, i would need to declare another String.
            I want to retrieve those images from the path of my xml file. Are you able to solve my doubts? Thanks for the help once again
            <mx:Script>
            <![CDATA[
            private var path1:String = "assets/open.gif";
            myImage1.source = path1;
            </mx:Script>
            <mx:Image id="myImage1" x="105" y="45"  width="37" height="49"/>
            </mx:Application>
            • 3. http://forums.adobe.com/thread/483306?tstart=0
              Niranjan_swain Level 1
              hi,
              if u faceing problem to retrive path from ur xml file this is the code of ur xml file given belo
                 * This function load the xml value from a file  to ur application
                 private function  loadXml():void
                 var xmlLoader:URLLoader = new URLLoader();
                  xmlLoader.load(new URLRequest("yourFileNmae.xml"));
                  xmlLoader.addEventListener(Event.COMPLETE, handleLoad);
              private var componentXml :Xml = new Xml();
              private var ImageList:XmlList = new XmlList();
                 *   This function call when the xml loading complete from external file
                 private function handleLoad(event:Event):void
                 componentXml = new XML(event.target.data);;
              ImageList = componentXml .memory.card.url;
              this imagelist varable all the xml tag which contain image.
              u iterate the imagelist variable and get the image path and assign to the image.
              suppose ur image is image1.
              u assign the firstimage to this image1.
              thenn
              image1.source = imageList[0];
              I think this will helpu;
              • 4. Re: http://forums.adobe.com/thread/483306?tstart=0
                shaylee tan Level 1
                Hi Niranjan. Sorry to bother you again. Are you able to type out the exact codes? Because there is an error and i am not able to figure it out. Thanks for your help once again.
                • 5. Re: http://forums.adobe.com/thread/483306?tstart=0
                  christopher.mina
                  Building on Niranjain_swain's reply:
                            var xml:XML = new XML(event.target.data);
                            var list:XMLList = xml.memory;
                            for each(var node:XML in list){
                               var source:String = node.card[0].url;
                               //this is the source url you are looking for.
                  • 6. Re: Retrieving image path from xml file for images
                    flex2008 Level 3
                    You can use two approaches:
                    Approach 1:
                    <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
                        <!--assuming details.xml is your xml file in the same folder as the mxml file-->
                        <mx:XML id="xml" source="details.xml"/>
                        <!--here i used the index directly to refer the xml nodes-->
                        <mx:Image x="104" y="184" source="{xml.memory[0]..url"/>
                        <mx:Image x="326" y="184" source="{xml.memory[1]..url}"/>
                    </mx:Application>
                    Approach2:
                    xml file should be modified as:
                    <!--I have used two nodes only-->
                       <memory>
                        <card>
                          <name>Torres</name>
                          <image>img1</image>
                        </card>
                        </memory>
                        </memory>
                        <memory>
                        <card>
                          <image>img2</image>
                        </card>
                        </memory>
                    </memoryCards>
                    your mxml file should be:
                        <mx:Script>
                            <![CDATA[
                                [Bindable]
                                [Embed(source="assets/torres.png")]
                                 private var img1:Class;
                                 [Bindable]
                                 [Embed(source="assets/lamps.png")]
                                 private var img2:Class;
                                 private function getImgClass(value:String):Class
                                    return this[value]
                        </mx:Script>
                        <mx:Image x="104" y="184" source="{getImgClass(xml.memory[0]..image)}"/>
                        <mx:Image x="326" y="184" source="{getImgClass(xml.memory[1]..image)}"/>
                    </mx:Application>
