2 Replies Latest reply on Aug 27, 2009 10:40 AM by Allen Gambrell
    User interface changes on user action?
    Allen Gambrell
      I am writing a plugin that loads fields from a csv file. I need to show a preview of those fields (say the first 3 rows) to the user so he can decide what type of field they are, ie date, name, address. What I want is a row of headers of popup boxes and the the first 3 rows under them. The problem is I don't know ahead of time how many columns there are.
      I thought I would make a varible to hold a columnview and bind to the correct place on the interface. Then loop though the file and build the preview data.I have tried this and cannot get the data to update on the screen and I am not sure exactly how to bind the varible to a columnview.
      Here is a preview of what I would want the data in the column view to be and then bind it to the.
      f:row {
            f:popup_menu {
                items = fielditems
            f:popup_menu {
                items = fielditems
           f:popup_menu {
                items = fielditems
      f:row {
           f:static_text {
                title = 'DataField1',
                alignment = "left",
                width_in_chars = 20
           f:static_text {
                 title = 'DataField2',
                 alignment = "left",
                 width_in_chars = 20
                f:static_text {
                 title = 'DataField3',
                 alignment = "left",
                 width_in_chars = 20
      Am I going about this the entire wrong way? At this point I am lost on how to build a interface that will update on user interaction. I have seen this type on interface on LR Transporter (the import metadata from file) so I know it is possible.
        • 1. Re: User interface changes on user action?
          john beardsworth Adobe Community Professional & MVP
          Allen, that sounds right - or at least is similar to the approach I've been adopting with a similar plug-in. Are the field names an array/table? There doesn't seem to be a native split function in Lua but there are a few examples which could split the first line using the commas.
          John
          • 2. Re: User interface changes on user action?
            Allen Gambrell Level 1
            I can get the data out of the csv file fine. I am just having major problems getting it to update the screen.
            here is how I am getting the data from the file to and putting into layout.
            function layoutDataFile (FilePath)
                path = LrPathUtils.standardizePath(FilePath)
                local file=io.open(path,'r')
                local line
                local firsttime = true
                local LayoutRows = {}
                local rowindex = 1
                local linecount = 0
                -- loop each line
                for line in file:lines() do
                    linecount = linecount + 1
                    if linecount > 4 then
                        -- Dont Add Lines after the 3rd
                    else
                        -- Convert Line to table with elements
                        t = fromCSV(line)
                        lRowItems = {}
                        -- First Time Through Make the Header Row
                        if firsttime==true then
                            for i, s in ipairs(t) do
                                BarcodeMatchLMI.outputToLog('    Add Item '..i)
                                nm = f:static_text {
                                        title = "Column"..i,
                                        alignment = "left",
                                        width_in_chars = 20
                                BarcodeMatchLMI.outputToLog('    Insert Item '..i)
                                table.insert(lRowItems,i,nm)
                            end
                            lRow = f:row {lRowItems}
                            table.insert(LayoutRows,rowindex,lRow)
                            rowindex = rowindex + 1
                            lRowItems = {}
                            firsttime = false
                        end
                        -- Add Fields to Row of the current Line
                                    title = s,
                                    alignment = "left",
                                    width_in_chars = 20
                        end
                        --Insert Row
                        BarcodeMatchLMI.outputToLog('  Insert Row '..rowindex)
                    end
                end
                file:close()
                -- Add Rows to Column Layout
                BarcodeDataLayout = f:column {LayoutRows}
                return DataLayout
                end
            Here is where I am using function. After a button press to select the file.
            SampleDataLayout = layoutDataFile (selectedpath)
            Here is the Layout. I tried to figure out how to bind it, but am trying to use a strait varible now because I could not figure out how to bind a column. I only say examples of binding the values and data of a control not the entire control.
            f:row {
                                f:group_box {
                                    title = "Barcode Data",
                                    font = "<system>",
                                    width = 750,
                                    height = 200,
                                    SampleDataLayout,
            And the where I declare the varible to hold the ui.
            local BarcodeDataLayout = f:column {}
            Does anyone have a better way that would work?
