4 Replies Latest reply on Aug 27, 2009 10:42 AM by AmitVyawahare
    How to change icon
    AmitVyawahare
      I created a desktop application using flex. I want to change the desktop icon which is defaultly created by flex.
      I have some sample icon with me. I like to change that default icon with new icon. Thank you.
      --Amit
        • 1. Re: How to change icon
          Ratsnackbar Level 2
          Setting icons for an AIR application is done in the configuration XML file under the Node <icon>.  It should look like this:
          <icon>
               <image16x16>assets/myIcon16.png</image16x16>
               <image32x32>assets/myIcon32.png</image32x32>
               <image48x48>assets/myIcon48.png</image48x48>
               <image128x128>assets/myIcon128.png</image128x128>
          </icon>
          Of course your icon names and possibly the path would be different.
          -Joe
          • 2. Re: How to change icon
            AmitVyawahare Level 1
            Joe,
            Where do i find  this configuration XML file.
            Thank you,
            --Amit
            • 3. Re: How to change icon
              Ratsnackbar Level 2
              If you are using Flex Builder (or Flash Builder) it is normally in the same location as your main mxml file.  It will be named something like yourApplicationName-app.xml
              The header of the file should look something like this.
              <?xml version="1.0" encoding="utf-8" standalone="no"?>
              <application xmlns="http://ns.adobe.com/air/application/1.5">
              <!-- Adobe AIR Application Descriptor File Template.
              The default properties of your AIR application will be laid out in XML.  Some of them are Optional.  It would be a good idea to check liveDocs for a complete description as a great many of the settings in the file are of great use in customizing your application.
              -Joe
              • 4. Re: How to change icon
                I tryed what you ask me do but i am getting error :
                Error creatating AIR file 308 ,Error ,/CheckWeather/src/Weather.png
                <icon>
                <image16x16>/CheckWeather/src/Weather.png</image16x16>
                <image32x32>/CheckWeather/src/Weather.png</image32x32>
                <image48x48>/CheckWeather/src/Weather.png</image48x48>
                <image128x128>/CheckWeather/src/Weather.png</image128x128>
                </icon>
                --Amit
