1 Reply Latest reply on Aug 27, 2009 2:14 AM by christopher.mina
    How to track border hover of text area?
    ckisthebest Level 1
      Hi All,
      I really need some idea. I am using text area which is movable. It moves when you drag it.
      Now i want to move it only while clicking on border. If you have seen text area in powerpoint on which if you hover on border it shows a + cursor.
      I want to implement same thing in flex. Does anyone have idea?
      -CK
        • 1. Re: How to track border hover of text area?
          christopher.mina Level 1
          add a mouseMove event listener to the text area.
          ta.addEventListener(MouseEvent.MOUSE_MOVE, onMouseMove);
          private var upperThreshold:int = 5;
          private var lowerThreshold:int = 10;
          private var leftThreshold:int = 3;
          private var rightThreshold:int = 6;
          private function onMouseMove(evt:MouseEvent):void{
               var isOnBorder:Boolean = false;
               if (ta.mouseY <= upperThreshold){
                  isOnBorder = true;
               }else if(ta.mouseY >= ta.height - lowerThreshold){
                  isOnBorder = true;
               }else if(ta.mouseX <= leftThreshold){
                   isOnBorder = true;
               }else if(ta.mouseX >= ta.width - rightThreshold){
                   isOnBorder = true;
               if (isOnBorder){
                   //set your styles and listen for mouse down event
               }else{
                   //remove your styles and mouse down event listener
          In the above example, you'll also want to listen for a mouse out even to so you can remove any styles and unwanted event listeners.
