0 Replies Latest reply on Aug 27, 2009 3:43 AM by ravindra.kumar
    Creating custom html-wrapper from ANT build
    ravindra.kumar
      I have been using flex from last six month. I am facing problem while creating html-wrapper. As per my requirement, my application need to run on all the browser. But whenever I use to run application on firefox, there is some focus related problem. For that I need to set wmode='opaque' and
      body scroll="no" onLoad="window.document.${application}.focus();">. But I am unable to find out how to set this property in html-wrapper through ant build.
      currently I am using following and script to build my flex application.
      <!-- compile flex source code -->
      <target name="compile.flex" description="Compile the Flex source code" unless="eclipse.running"
      <taskdef resource="flexTasks.tasks" classpath="${flex.home}/ant/lib/flexTasks.jar"
      <echo level="info">Compiling flex mxml
      </echo>
      <property name="FLEX_HOME" value="${flex.home}"
      <mxmlc file="${basedir}/src/main/flex/main.mxml" output="${exploded.dir}/${project.name}.swf" actionscript-file-encoding="UTF-8" incremental="true" services="${basedir}/src/main/resources/services-config.xml" context-root="/${project.name}"
      <source-path path-element="${basedir}/src/main/resources/messages/{locale}"
      <!-- Get default compiler options. -->
      <load-config filename="${flex.home}/frameworks/flex-config.xml"
      <!-- List of path elements that form the roots of ActionScript class hierarchies. -->
      <!--<source-path path-element="${view.dir}/flex/assets" />-->
      <compiler.library-path dir="${flex.lib.dir}" append="true"
      <include name="*"
      </compiler.library-path>
      </mxmlc>
      <echo level="info">Generating html
      </echo>
      <html-wrapper title="${project.name}" file="${project.name}.html" application="app" swf="${project.name}" version-major="9" version-minor="0" version-revision="0" width="100%" height="100%" history="true" template="client-side-detection" output="${exploded.dir}"
      </target>
      I have also tried to edit respective index.template.html file in flex SDK, but that also doesn't work. Please suggest what shoud I do?
      Thanks and Regards,
      Ravindar kumar
