4 Replies Latest reply on Feb 6, 2010 6:30 AM by kjøtern
    Big DNG files from E-P1 RAWs
    schulzml
      I am converting RAW files from my E-P1 to DNG using the new DNG Converter 5.5RC. To use the DNGs in Lightroom 1.0 I have to use "Camera RAW 4.6 and newer" as compatibility setting. This results in extremly big DNG files (I did not embed the original RAW).
      original ORF file:12.2 MB
      converted DNG 4.6: 46.6 MB
      converted DNG 5.4: 12.7 MB
      This problem only occurs with pictures taken with the olympus kit lens. Pictures taken with an old adapted manual lens don't have that problem. I suspect that the problem relates to the lens corretion data, that is only present with the kit lens.
      Does anyone have the same problem? Is this a general problem with old DNG versions or a bug in the DNG Converter 5.5RC?
      Michael
        • 1. Re: Big DNG files from E-P1 RAWs
          Panoholic Level 2
          In order to perform the lens correction, the pixels have to be de-mosaiced first. The resulting DNG file contains three components (R,G,B) instead of the single component in the raw data; in effect, the amount of image data becomes tripled; this format is mis-called "linear" in the DNG terminology.
          Gabor
          • 2. Re: Big DNG files from E-P1 RAWs
            schulzml Level 1
            Then my guess aboute the lens correction was right. Would be nice to have the option to switch off lens correction in this case, since as i understand the DNG only contains the demosaiced, lens corrected data and no longer the original RAW data.
            Thanks for the clarification.
            Michael
            • 3. Re: Big DNG files from E-P1 RAWs
              Panoholic Level 2
              Can not you disable the lens correction feature in your camera?
              I am not speaking for Adobe, but I "feel their pain": the Oly lens correction is only one feature of many-many among all native raw files. If the DNG interface contained options for all featires, which may be reasonable candidate for disabling, the dialog would become horrendeous.
              The core of the problem is, that the previous DNG version [i]could not[/i] carry the lens correction info, for the specification did not have a respective element for that. Therefor the DNG converter has to perform the correction itself, instead of letting the "real" raw processing do that. This has been mended in the newer version, i.e. the DNG converter can now "pass" the lens correction info to the raw processor in meta format, the raw data itself does not need to be changed during the conversion in DNG.
              Gabor
              • 4. Re: Big DNG files from E-P1 RAWs
                kjøtern
                I am also getting DNG files ranging from 3 to 6 times larger than the original ORF when using DNG Converter on images taken with my OLY M43 17/2.8 lens. The problem is documented (with sample files from both the OLY 17/2.8 and a ZN 28/2.8 on an adapter) in the folder: http://abdallah.hiof.no/photography/oly-ep2-test/. Not only do the files grow to significantly larger, but those from the OLY lens do not have thumbnails that are visible in the Mac OS Finder while those from adapter mounted lenses do.
                Do we really have to live with this problem or is there hope that DNG Converter will produced a normal sized file after doing the correction specified by the embedded metadata? Could at least the embedded JPEG thumbnails be made visible?
                - Børre Ludvigsen
