3 Replies Latest reply on Aug 27, 2009 11:39 AM by Barna Biro
    Expand the tree by default
    hclselvs Level 1
      I have a tree component  in my Application and I have given the dataprovider as XMLListCollection. I would like to have the entire tree as expanded mode(all children) by default. To achieve this, I tried expandItem() method but I couldn't see the entire tree as expanded when I load my application.
      Any solution will be helpful for me a lot!
      Thanks in Advance,
      Srinivasan S
        • 1. Re: Expand the tree by default
          Luke Immes
          This is tricky, but the following file works for me: all nodes expanded.
          The key is pre-initialize.
          • 2. Re: Expand the tree by default
            Luke Immes Level 1
            <?xml version="1.0"?>
            Read .xml file, labeled nodes, open as expanded tree.
            Use preinitialize, so that .xml data from file is loaded BEFORE, we initTree(), else xmlValue will be empty in XMLTree1.
            <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml" label="tree"
            preinitialize="xmlLoader.send()"
                <mx:Script>
                        import mx.events.*;
                        import mx.collections.XMLListCollection;
                     [Bindable]
            private var xmlValue:XMLListCollection;
                        private function initTree():void {
                            XMLTree1.expandChildrenOf(XMLTree1.dataProvider[0],true);
            private function xmlReturned(event:Event):void {
            xmlValue = new XMLListCollection(new XMLList(xmlLoader.lastResult));
                </mx:Script>
            <mx:HTTPService id="xmlLoader" url="data/dashboardLabeled.xml" resultFormat="e4x" contentType="application/xml"
            result="xmlReturned(event)"
                <mx:Tree id="XMLTree1"
                width="288"
                height="696"
                horizontalScrollPolicy="on"
                x="0" y="49"
                borderStyle="solid" backgroundColor="#8481EF" themeColor="#FFE400"
                        labelField="@label"
                        dataProvider="{xmlValue}"
                        creationComplete="initTree()"
                </mx:Tree>
            </mx:Canvas>
            • 3. Re: Expand the tree by default
              Barna Biro Level 3
              A more elegant solution ( in my opinion ) would be to extend the Tree component and implement the desired behavior in a much nicer fashion. It is true that we already have expandChildrenOf(); method that is really great, but if we want to have a nice feature that instantaneously expands or collapses the whole tree more easily ( without having to rewrite the same conditions and who knows what each time we want such a functionality ) then I think that it would be much nicer to extend the Tree component, add the desired feature and start using that custom component instead.
              Here's a fast example ( make sure to place this class into a "components" folder if you want to test it ):
              package components
                  import mx.controls.Tree;
                  * Custom <code>Tree</code> class with custom behavior.
                  public class ExpandableTree extends Tree
                      * Flag telling if the tree is expanded or not.
                      protected var _isExpanded:Boolean = false;
                      * Constructor.
                      public function ExpandableTree()
                          super();
                      * Used to expand or collapse the <code>Tree</code>.
                      * @param value Flag telling if we should expand or collapse the <code>Tree</code>.
                      protected function expandCollapseTree(value:Boolean):void
                          // Return if there's no data to expand or collapse.
                          if (this.dataProvider == null)
                              // The flag should be "false" if no expanding has occurred.
                              _isExpanded = false;
                              return;
                          // Expand or collapse the children.
                          this.expandChildrenOf(this.dataProvider[0], value);
                      //  Overridden methods
                      * @inheritDoc
                      override protected function updateDisplayList(w:Number, h:Number):void
                          // Expand or collapse the Tree.
                          expandCollapseTree(_isExpanded);
                          super.updateDisplayList(w, h);
                      //  Setters and getters
                      * Set a flag telling if the <code>Tree</code> should be expanded or callapsed.
                      public function set expanded(value:Boolean):void
                          // Make sure that the passed value is not the current state.
                          if (value == _isExpanded) return;
                          _isExpanded = value;
                          // Invalidate the display list to signal the change.
                          this.invalidateDisplayList();
                      * Returns the current state of the <code>Tree</code>.
                      public function get expanded():Boolean
                          return _isExpanded;
              Obviously, you can always extend this "skeleton component" and add even more features. Also, there's another fast example to demonstrate the usage of the component I've just posted above ( it's really simple ):
              <mx:Application
                  xmlns:mx                    = "http://www.adobe.com/2006/mxml"
                  xmlns:components            = "components.*"
                  backgroundColor             = "0xFFFFFF"
                  backgroundGradientColors    = "[0xFFFFFF, 0xFFFFFF]"
                  layout                      = "vertical">
                  <mx:XMLList id="treeData">
                      <node label="Mail Box">
                          <node label="Inbox">
                              <node label="Marketing"/>
                              <node label="Product Management"/>
                              <node label="Personal"/>
                          </node>
                          <node label="Outbox">
                              <node label="Professional"/>
                              </node>
                          </node>
                          <node label="Spam"/>
                          <node label="Sent"/>
                      </node>
                  </mx:XMLList>
                  <components:ExpandableTree
                      id              = "cmpExpandableTree"
                      width           = "400"
                      height          = "300"
                      showRoot        = "false"
                      expanded        = "true"
                      labelField      = "@label"
                      dataProvider    = "{treeData}"/>
                  <mx:HBox width="400">
                      <mx:Button
                          label       = "Collapse"
                          width       = "100%"
                          click       = "cmpExpandableTree.expanded = false;"/>
                      <mx:Button
                          label       = "Expand"
                          width       = "100%"
                          click       = "cmpExpandableTree.expanded = true;"/>
                  </mx:HBox>
              </mx:Application>
              So, this would be the "neater solution" ( in my opinion ). But simply using expandChildrenOf(); and passing in the item from where you want to rest of the nodes to expand is just as valid.
              With kind regards,
              Barna Biro
