10 Replies Latest reply on Jun 20, 2008 12:08 PM by kglad
    getURL problem
      Hi kglad, anyone else,
      I've created a Flash file in Flash 8 Prof. and have a page where there are a number of links to external websites. When tested from home these all work fine, however, when the Flash file is 'published' and run through Internet Explorer 7 at work none of these links work.
      I've looked through MASSES of correspondence on this and other forums which seem to suggest that it is the html code which needs changing. So, as suggested, I changed the allowScriptAccess in the html file to "always" but, alas, this still has no effect. Do I need to change the publish settings in the main Flash file too for this to have an effect? If not, has anyone got any other suggestions?
      Kind regards
