8 Replies Latest reply on Sep 15, 2009 10:02 AM by trancepriest
    Using Horizontal/Vertical Scrollbars without a datalist.
    Luke Pearce Level 1
      I want to use a horizontal scrollbar in a web application Im working on but don't want to create a datalist. I just want to be able to scroll content across a bounded area. Is this possible in catalyst itself?
      Thanks for any help,
      Luke.
        • 1. Re: Using Horizontal/Vertical Scrollbars without a datalist.
          acath Level 4
          Hi Luke,
          There's no easy way to do this in the current beta, but check again in the next beta.
          For now, you can do this with some coding in Flash Builder:
          1.  Convert the content that you want to scroll to a custom component.
          2.  Create a scrollbar that you want to scroll the content.
          3.  Import your project to Flash Builder.
          4.  Find your custom component in the code. It will look like this:
          And add this:
          <HScrollBar viewport="scrollingArea"...
          Voila!
          -Adam
          • 2. Re: Using Horizontal/Vertical Scrollbars without a datalist.
            Luke Pearce Level 1
            Thanks Adam i'll give that a try.
            Luke.
            • 3. Re: Using Horizontal/Vertical Scrollbars without a datalist.
              Luke Pearce Level 1
              Hi Adam.
              Ive finally come around to trying to edit the code in flash builder and I think you missed out some text in your reply. Where you've said what the custom component will look like there isnt any text.
              Ive been reading further and am I right in saying that i need the custom component to be the viewport for the scroll bar?
              thanks,
              luke.
              • 4. Re: Using Horizontal/Vertical Scrollbars without a datalist.
                acath Level 4
                Hi Luke,
                Sorry about that. The forum seems to have problems with email responses...here's my original full reply:
                Hi Luke,
                There’s no easy way to do this in the current beta, but check again in the next beta.
                <CustomComponent1 ...
                Add this stuff:
                <CustomComponent1 id=”scrollingArea” width=”100” height=”100” clipAndEnableScrolling=”true” ...
                (of course, you can set the width and height to whatever you want the clipped, viewable area to be).
                5. Now find your scrollbar. It will look like this:
                <HScrollBar .../>
                And add this:
                <HScrollBar viewport=”scrollingArea”...
                Voila!
                -Adam
                • 5. Re: Using Horizontal/Vertical Scrollbars without a datalist.
                  Luke Pearce Level 1
                  thank you! I got it all working at last! Only thing I had to change was when adding the viewport tag in the scrollbar I needed to put { } around the id.
                  thanks,
                  luke.
                  • 6. Re: Using Horizontal/Vertical Scrollbars without a datalist.
                    trancepriest Level 1
                    Thanks this seems like it will be a solution to my current problem of trying to create external urls in a flash catalyst design time data list.
                    • 7. Re: Using Horizontal/Vertical Scrollbars without a datalist.
                      Cannot get it to work with the following code:
                      <components:CustomComponent1 includeIn="Portfolio" x="380" y="60" id="PortfolioScrollingArea" width="580" height="420" clipAndEnableScrolling="true">
                      </components:CustomComponent1>
                      <s:VScrollBar includeIn="Portfolio" x="967" y="60" id="vscrollbar1" skinClass="components.VerticalScrollbar2" fixedThumbSize="true" viewport="PortfolioScrollingArea"/>
                      I tried using {} around the viewport tag id and still wasn't working. Any help would be very much appreciated.
                      The error result is:
                      Description Resource Path Location Type
                      Initializer for 'viewport': values of type spark.core.IViewport cannot be represented in text. Main.mxml facetmediacomp-scrollbar/src line 941 Flex Problem
                      *** Disregard... problem solved with:
                      <s:VScrollBar includeIn="Portfolio" x="967" y="60" id="vscrollbar1" skinClass="components.VerticalScrollbar2" fixedThumbSize="true" viewport="{PortfolioScrollingArea}"/>
                      A secondary error was reported elsewhere after this change due to the default FC target tag needed to be changed... to "PortfolioScrollingArea"
                      • 8. Re: Using Horizontal/Vertical Scrollbars without a datalist.
                        How do you add buttons to the scrolled content when the content extends beyond the artboard?
                        http://facetmedia.com/new/
                        I was able to create the vertical scroll bar/custom component but now the buttons are stuck in place on the portfolio page.
