0 Replies Latest reply on Aug 27, 2009 2:20 PM by Flex harUI
    [svn:fx-trunk] 9715: Introduce tabFocusEnabled to IFocusManagerComponent.
    Flex harUI Adobe Employee
      Revision: 9715
      Author:   aharui@adobe.com
      Date:     2009-08-27 14:20:28 -0700 (Thu, 27 Aug 2009)
      Log Message:
      Introduce tabFocusEnabled to IFocusManagerComponent.  This replaces tabEnabled as the way to remove a component from the tabbing loop.  tabEnabled should be set to true for any component that can receive focus, and tabFocusEnabled determines whether the FocusManager will actually give it focus.  If tabEnabled=false on a non-TextField, the player will sometimes momentarily remove focus and dispatch a focusOut when the component has focus and is later clicked on.  This is now quite common with TLF-based text components so we are forced to make this change.
      QE Notes: tests using tabEnabled must now use tabFocusEnabled
      Doc Notes: needs documentation
      Bugs: SDK-22731
      Reviewer: Gordon
      API Change: Yes
      Is noteworthy for integration: Yes
      tests: checkintests cyclone
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22731
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/controls/HTML.as
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/core/FlexHTMLLoader.as
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/core/Window.as
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Accordion.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/TabNavigator.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/accordionClasses/Accordion Header.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ButtonBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ComboBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateChooser.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Image.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Menu.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/SWFLoader.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/sliderClasses/Slider.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/events/FlexEvent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/FocusManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/IFocusManagerComponent.as
