0 Replies Latest reply on Aug 27, 2009 3:59 PM by Jason Szeto
    [svn:fx-trunk] 9724: Border checkin
    Jason Szeto Level 3
      Revision: 9724
      Author:   jszeto@adobe.com
      Date:     2009-08-27 15:59:23 -0700 (Thu, 27 Aug 2009)
      Log Message:
      Border checkin
      The Border class provides a container class that can be styled with a border and a background fill or image. It has many of the same styles as HaloBorder and is used in a similar way to the Halo container classes such as Box and Canvas. Examples of styles that are supported are borderWeight, borderColor, backgroundColor, backgroundImage, cornerRadius and dropShadowVisible. The class also supports directly setting a fill or stroke instance.
      Border consists of a component class and a skin class called BorderSkin. Border declares the available styles and the backgroundFill and borderStroke properties. It serves as a proxy for the styles and properties in BorderSkin. BorderSkin draws the border and background using these styles and properties. The Border class is not meant to be skinned by a different skin class. All of the style drawing logic is held in the BorderSkin class.
      QE notes: None
      Doc notes: ASDoc comments need review
      Bugs: N/A
      Reviewer: Glenn
      Tests run: Added Border to checkintests
      Is noteworthy for integration: Yes. Border is a new container.
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/defaults.css
          flex/sdk/trunk/frameworks/projects/spark/src/SparkClasses.as
          flex/sdk/trunk/frameworks/spark-manifest.xml
          flex/sdk/trunk/frameworks/tests/basicTests/BasicTests-config.xml
          flex/sdk/trunk/frameworks/tests/basicTests/BasicTests.mxml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Border.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/BorderSkin.as
          flex/sdk/trunk/frameworks/tests/basicTests/spark/scripts/BorderTestScript.mxml
          flex/sdk/trunk/frameworks/tests/basicTests/spark/views/BorderTests.mxml
