3 Replies Latest reply on Sep 3, 2009 4:20 AM by Sedat Reyhan
    CALL STORED PROCEDURE, STRING PARAMETER VALUES ARE LOST
    Sedat Reyhan
      Hello,
      I need really urgent and critical help!
      After a user completes the task in workspace (fills a form), there is a "Call Stored Procedure" operation.
      This operation passes 85 piece of INT and STRING parameters to a procedure in Oracle db
      (parameter values are from the form-xpath- that the user filled in ws).
      The problem is: String values are mostly seen as emty values, but sometimes not!
      When i tested it first time, all values (85 piece) are ,nserted to the db, but in the second time and later, non of the string values are inserted into the db.
      Could you advice pls?
      Best regards,
      Sedat Reyhan
