10 Replies Latest reply on Aug 28, 2009 7:59 AM by wesandmarlene
    Component on page not moving as vertical scroll bar is moved
    wesandmarlene
      All -
      I have a mxml page that is a mx:Application.  This page basically consists of a VBox
      and a number of components included within that VBox.  All but 1 of the components
      within this VBox are built-in flex components.  The one component that is not a built-in
      flex component is the one that is causing me issues.  The issue is happening when I run
      the application, once running the vertical scroll bar appears on the right-hand side of the
      page (as expected because I have quite a few items in my VBox).  The problem is that as
      I drag the vertical scroll bar from the top of the page to the bottom of the page, the custom
      component within my VBox that I built is staying put (it's not moving with respect of the
      movement of the vertical scroll bar).  All of the built-in flex components that are within my
      VBox are moving with respect of the movemnet of the vertical scroll bar as expected.
      I appreciate any information that you can provide that will lead me in the right direction,
      Thank you,
      Wes
        • 1. Re: Component on page not moving as vertical scroll bar is moved
          Andrew Rosewarn Level 3
          Soory to ask but are you sure its in there and you haven't just dropped it on the application in descign mode and it just looks like it in there.  Check the mxml to be sure its inside the vbox tags.
          If so, check your custom component doesn't have the includeInLayout property set to false.
          If none of the above helps past in some code to show the application and the custom component.
          • 2. Re: Component on page not moving as vertical scroll bar is moved
            wesandmarlene Level 1
            Hello,
            Yes, I'm positive it's within the VBox tags, I've verified the source xml.  I did a search on the includeInLayout
            variable that you mention in my custom component and it is not even present in the code, so I don't believe
            this is the problem.
            Wes
            • 3. Re: Component on page not moving as vertical scroll bar is moved
              Any chance of attaching some sample code?
              • 4. Re: Component on page not moving as vertical scroll bar is moved
                Is your custom component a UI Component, cos I think it needs to be to work in the layout of flex containers?
                Is not a sprite, shape or somthing else is it?
                • 5. Re: Component on page not moving as vertical scroll bar is moved
                  I've attached "IFrame.as" which is the custom component within my VBox.
                  The other attached file is the mx:application file that has the VBox that includes
                  the IFrame within it.
                  Wes
                  • 7. Re: Component on page not moving as vertical scroll bar is mo
                    Sorry Wes can;t see the attachments?
                    • 8. Re: Component on page not moving as vertical scroll bar is moved
                      // THIS IS THE CUSTOM COMPONENT
                      package
                      import
                      flash.display.DisplayObject;
                      import
                      flash.display.DisplayObjectContainer;
                      import
                      flash.events.Event;
                      import
                      flash.external.ExternalInterface;
                      import
                      flash.geom.Point;
                      import
                      flash.utils.Dictionary;
                      import
                      mx.core.Application;
                      import
                      mx.core.Container;
                      import
                      mx.core.UIComponent;
                      import
                      mx.events.FlexEvent;
                      import
                      mx.events.IndexChangedEvent;
                      import
                      mx.events.MoveEvent;
                      import
                      mx.logging.ILogger;
                      import
                      mx.logging.Log;
                      import
                      mx.logging.targets.TraceTarget;
                      import
                      mx.managers.BrowserManager;
                      import
                      mx.utils.URLUtil;
                      Event(name="frameLoad", type="flash.events.Event"
                      public class IFrame extends
                      Container
                      public var debug:Boolean = false
                      public var overlayDetection:Boolean = false
                      private var
                      logTarget:TraceTarget;
                      private var
                      __source: String;
                      private var
                      __content: String;
                      private var
                      frameId:String;
                      private var
                      iframeId:String;
                      private var validForDisplay:Boolean = true
                      private var containerDict:Object = null
                      private var settingDict:Object = null
                      private var frameLoaded:Boolean = false
                      private var
                      functionQueue:Array = [];
                      private static var logger:ILogger = Log.getLogger("com.plus.arutherford.ccgi.IFrame"
                      * Here we define javascript functions which will be inserted into the DOM
                      private static var
                      FUNCTION_CREATEIFRAME:String =
                      "document.insertScript = function ()"
                      "if (document.createIFrame==null)"
                      "createIFrame = function (frameID)"
                      "var bodyID = document.getElementsByTagName(\"body\")[0];"
                      "var newDiv = document.createElement('div');"
                      "newDiv.id = frameID;"
                      "newDiv.style.position ='absolute';"
                      "newDiv.style.backgroundColor = 'transparent';"
                      "newDiv.style.border = '0px';"
                      "newDiv.style.visibility = 'hidden';"
                      "bodyID.appendChild(newDiv);"
                      private static var
                      FUNCTION_MOVEIFRAME:String =
                      "if (document.moveIFrame==null)"
                      "moveIFrame = function(frameID, iframeID, x,y,w,h) "
                      "var frameRef=document.getElementById(frameID);"
                      "frameRef.style.left=x;"
                      "frameRef.style.top=y;"
                      "var iFrameRef=document.getElementById(iframeID);"
                      "iFrameRef.width=w;"
                      "iFrameRef.height=h;"
                      private static var
                      FUNCTION_HIDEIFRAME:String =
                      "if (document.hideIFrame==null)"
                      "hideIFrame = function (frameID, iframeID)"
                      "var iframeRef = document.getElementById(iframeID);"
                      "var iframeDoc;"
                      "if (iframeRef.contentWindow) {"
                      "iframeDoc = iframeRef.contentWindow.document;"
                      "} else if (iframeRef.contentDocument) {"
                      "iframeDoc = iframeRef.contentDocument;"
                      "} else if (iframeRef.document) {"
                      "iframeDoc = iframeRef.document;"
                      "if (iframeDoc) {"
                      "iframeDoc.body.style.visibility='hidden';"
                      "document.getElementById(frameID).style.visibility='hidden';"
                      private static var
                      FUNCTION_SHOWIFRAME:String =
                      "if (document.showIFrame==null)"
                      "showIFrame = function (frameID, iframeID)"
                      "document.getElementById(frameID).style.visibility='visible';"
                      "var iframeDoc;"
                      "if (iframeDoc) {"
                      "iframeDoc.body.style.visibility='visible';"
                      private static var
                      FUNCTION_HIDEDIV:String =
                      "if (document.hideDiv==null)"
                      "hideDiv = function (frameID, iframeID)"
                      private static var
                      FUNCTION_SHOWDIV:String =
                      "if (document.showDiv==null)"
                      "showDiv = function (frameID, iframeID)"
                      private static var
                      FUNCTION_LOADIFRAME:String =
                      "if (document.loadIFrame==null)"
                      "loadIFrame = function (frameID, iframeID, url)"
                      "document.getElementById(frameID).innerHTML = \"<iframe id='\"+iframeID+\"' src='\"+url+\"' onLoad='"
                      + Application.application.id +
                      ".\"+frameID+\"_load()' frameborder='0'></iframe>\";"
                      private static var
                      FUNCTION_LOADDIV_CONTENT:String =
                      "if (document.loadDivContent==null)"
                      "loadDivContent = function (frameID, iframeID, content)"
                      "document.getElementById(frameID).innerHTML = \"<div id='\"+iframeID+\"' frameborder='0'>\"+content+\"</div>\";"
                      private static var
                      FUNCTION_CALLIFRAMEFUNCTION:String =
                      "if (document.callIFrameFunction==null)"
                      "callIFrameFunction = function (iframeID, functionName, args)"
                      "var iframeRef=document.getElementById(iframeID);"
                      "var iframeDoc;"
                      "if (iframeRef.contentDocument) {"
                      "} else if (iframeRef.contentWindow) {"
                      "if (iframeDoc.wrappedJSObject != undefined) {"
                      "iframeDoc = iframeDoc.wrappedJSObject;"
                      "return iframeDoc[functionName](args);"
                      * Track IDs in use throughout the app for iframe
                      * instances in order to detect and prevent collisions
                      public static var idList:Object = new
                      Object();
                      private var
                      appHost:String;
                      private var
                      iframeContentHost:String;
                      * Constructor
                      public function
                      IFrame()
                      super
                      this
                      .addEventListener(Event.REMOVED_FROM_STAGE, handleRemove);
                      this
                      .addEventListener(Event.ADDED_TO_STAGE, handleAdd);
                      * Generate DOM elements and build display path.
                      override protected function createChildren():
                      void
                      super
                      .createChildren();
                      if
                      (! ExternalInterface.available)
                      throw new Error("ExternalInterface is not available in this container. Internet Explorer ActiveX, Firefox, Mozilla 1.7.5 and greater, or other browsers that support NPRuntime are required."
                      if
                      (debug)
                      logTarget =
                      new
                      TraceTarget();
                      logTarget.addLogger(logger);
                      // Get the host info to check for cross-domain issues
                      BrowserManager.getInstance().initForHistoryManager();
                      var
                      url:String = BrowserManager.getInstance().url;
                      appHost = URLUtil.getProtocol(url) +
                      + URLUtil.getServerNameWithPort(url);
                      // Generate unique id's for frame div name
                      var
                      idSuffix:int = 0;
                      while
                      (idList[id + idSuffix])
                      idSuffix++;
                      frameId = id + idSuffix;
                      iframeId =
                      "iframe_"
                      +frameId;
                      idList[frameId] =
                      true
                      // Register a uniquely-named load event callback for this frame (for load notification)
                      ExternalInterface.addCallback(frameId +
                      "_load", this
                      .handleFrameLoad);
                      // Add functions to DOM if they aren't already there
                      ExternalInterface.call(FUNCTION_CREATEIFRAME);
                      ExternalInterface.call(FUNCTION_MOVEIFRAME);
                      ExternalInterface.call(FUNCTION_HIDEIFRAME);
                      ExternalInterface.call(FUNCTION_SHOWIFRAME);
                      ExternalInterface.call(FUNCTION_SHOWDIV);
                      ExternalInterface.call(FUNCTION_HIDEDIV);
                      ExternalInterface.call(FUNCTION_LOADIFRAME);
                      ExternalInterface.call(FUNCTION_LOADDIV_CONTENT);
                      ExternalInterface.call(FUNCTION_CALLIFRAMEFUNCTION);
                      // Insert frame into DOM using our precreated function 'createIFrame'
                      "createIFrame"
                      , frameId);
                      buildContainerList();
                      if
                      (loadIndicatorClass)
                      logger.debug(
                      "loadIndicatorClass is {0}"
                      , loadIndicatorClass);
                      _loadIndicator = UIComponent(
                      new
                      loadIndicatorClass());
                      addChild(_loadIndicator);
                      else
                      logger.debug(
                      "loadIndicatorClass is null"
                      * Build list of container objects on the display list path all the way down
                      * to this object. We will seed the container classes we find with an event
                      * listener which will be used to test if this object is to be displayed or not.
                      private function buildContainerList():
                      void
                      // We are going to store containers against index of child which leads down
                      // to IFrame item.
                      containerDict =
                      new
                      Dictionary();
                      settingDict =
                      new
                      Dictionary();
                      var
                      current:DisplayObjectContainer = parent;
                      var previous:DisplayObjectContainer = this
                      while (current!=null
                      if (current is
                      Container)
                      if
                      (current.contains(previous))
                      var
                      childIndex:Number = current.getChildIndex(previous);
                      logger.debug(
                      "index: {0}"
                      , childIndex);
                      // Store child index against container
                      containerDict[current] = childIndex;
                      settingDict[current] = childIndex;
                      // Tag on a change listener
                      current.addEventListener(IndexChangedEvent.CHANGE, handleChange);
                      current.addEventListener(MoveEvent.MOVE, handleMove);
                      previous = current;
                      current = current.parent;
                      // make sure frame runs visible setter using initial visible state
                      visible = visible;
                      * Triggered by removal of this object from the stage
                      * @param event Event trigger
                      private function handleRemove(event:Event):
                      void
                      // Remove systemManager hooks for overlay detection
                      if
                      (overlayDetection)
                      systemManager.removeEventListener(Event.ADDED, systemManager_addedHandler);
                      systemManager.removeEventListener(Event.REMOVED, systemManager_removedHandler);
                      visible =
                      false
                      * Triggered by addition of this object to the stage
                      private function handleAdd(event:Event):
                      void
                      // Hook the systemManager to provide overlaying object detection
                      if
                      (overlayDetection)
                      systemManager.addEventListener(Event.ADDED, systemManager_addedHandler);
                      systemManager.addEventListener(Event.REMOVED, systemManager_removedHandler);
                      visible =
                      true
                      * Triggered by one of our listeners seeded all the way up the display
                      * list to catch a 'changed' event which might hide or display this object.
                      private function handleChange(event:Event):
                      void
                      var
                      target:Object = event.target;
                      if (event is
                      IndexChangedEvent)
                      var
                      changedEvent:IndexChangedEvent = IndexChangedEvent(event)
                      var
                      newIndex:Number = changedEvent.newIndex;
                      visible = checkDisplay(target, newIndex);
                      * list to catch a 'move' event which might reposition this object.
                      private function handleMove(event:Event):
                      void
                      moveIFrame();
                      * This function updates the selected view child of the signalling container
                      * and then compares the path from our IFrame up the displaylist to see if
                      * the index settings match. Only an exact match all the way down to our
                      * IFrame will satisfy the condition to display the IFrame contents.
                      * @param target Object event source
                      * @param newIndex Number index from target object.
                      private function
                      checkDisplay(target:Object, newIndex:Number):Boolean
                      var valid:Boolean = false
                      if (target is
                      Container)
                      var
                      container:DisplayObjectContainer = DisplayObjectContainer(target);
                      // Update current setting
                      settingDict[container] = newIndex;
                      valid =
                      true
                      for (var item:Object in
                      containerDict)
                      var index:Number = lookupIndex(item as
                      Container);
                      var setting:Number = lookupSetting(item as
                      Container);
                      logger.debug(item.toString());
                      valid = valid&&(index==setting);
                      // Remember this state so we can re-check later without a new IndexChangedEvent
                      validForDisplay = valid;
                      return
                      valid;
                      * Return index of child item on path down to this object. If not
                      * found then return -1;
                      * @param target Container object
                      public function
                      lookupIndex(target:Container):Number
                      var
                      index:Number = -1;
                      try
                      index = containerDict[target];
                      catch
                      (e:Error)
                      // Error not found, we have to catch this or a silent exception
                      // will be thrown.
                      logger.debug(e.toString());
                      return
                      index;
                      public function
                      lookupSetting(target:Container):Number
                      var
                      index:Number = -1;
                      try
                      index = settingDict[target];
                      catch
                      (e:Error)
                      // will be thrown.
                      return
                      index;
                      * Adjust frame position to match the exposed area in the application.
                      private function moveIFrame():
                      void
                      var localPt:Point = new
                      Point(0, 0);
                      var globalPt:Point = this
                      .localToGlobal(localPt);
                      "moveIFrame", frameId, iframeId, globalPt.x, globalPt.y, this.width, this
                      .height);
                      logger.debug(
                      "move iframe id {0}"
                      , frameId);
                      * Triggered by change to component properties.
                      override protected function commitProperties():
                      void
                      super
                      .commitProperties();
                      if
                      (source)
                      frameLoaded =
                      false
                      "loadIFrame"
                      , frameId, iframeId, source);
                      logger.debug(
                      "load Iframe id {0}"
                      , frameId);
                      // Trigger re-layout of iframe contents.
                      invalidateDisplayList();
                      else if
                      (content)
                      "loadDivContent"
                      , frameId, iframeId, content);
                      logger.debug(
                      "load Content id {0}"
                      , frameId);
                      protected function handleFrameLoad():
                      void
                      logger.debug(
                      "browser reports frame loaded with id {0}"
                      , frameId);
                      frameLoaded =
                      true
                      var
                      queuedCall:Object;
                      var
                      result:Object;
                      // Execute any queued function calls now that the frame is loaded
                      while
                      (functionQueue.length > 0)
                      queuedCall = functionQueue.pop();
                      logger.debug(
                      "frame id {0} calling queued function {1}"
                      , frameId, queuedCall.functionName);
                      this
                      .callIFrameFunction(queuedCall.functionName, queuedCall.args, queuedCall.callback);
                      dispatchEvent(
                      new Event("frameLoad"
                      * Triggered when display contents change. Adjusts frame layout.
                      * @param unscaledWidth
                      * @param unscaledHeight
                      override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):
                      void
                      super
                      .updateDisplayList(unscaledWidth, unscaledHeight);
                      if
                      (_loadIndicator)
                      if
                      (frameLoaded)
                      _loadIndicator.visible =
                      false
                      else
                      true
                      var
                      w:int = _loadIndicator.measuredWidth;
                      var
                      h:int = _loadIndicator.measuredHeight;
                      _loadIndicator.setActualSize(w, h);
                      _loadIndicator.move(
                      this.width / 2 - w, this
                      .height / 2 - h);
                      moveIFrame();
                      * Set source url
                      * @param url Frame contents
                      public function set source(source: String):
                      void
                      if
                      (source)
                      __source = source;
                      // mark unloaded now so calls in this frame will be queued
                      frameLoaded =
                      false
                      invalidateProperties();
                      iframeContentHost = URLUtil.getProtocol(source) +
                      + URLUtil.getServerNameWithPort(source);
                      * Return url of frame contents
                      public function get
                      source(): String
                      return
                      __source;
                      * Set content string
                      public function set content(content: String):
                      void
                      if
                      (content)
                      __content = content;
                      * Return content string of div contents
                      public function get
                      content(): String
                      return
                      __content;
                      * Sets visibility of html iframe. Rtn calls inserted javascript functions.
                      * @param visible Boolean flag
                      override public function set visible(value: Boolean):
                      void
                      super
                      .visible = value;
                      // if we have an iframe in the same domain as the app, call the
                      // specialized functions to update visibility inside the iframe
                      if
                      (visible)
                      if
                      (source && iframeContentHost == appHost)
                      "showIFrame"
                      ,frameId,iframeId);
                      else
                      "showDiv"
                      ,frameId,iframeId);
                      logger.debug(
                      "show iframe id {0}"
                      , frameId);
                      else
                      if
                      "hideIFrame"
                      ,frameId,iframeId);
                      else
                      "hideDiv"
                      ,frameId,iframeId);
                      logger.debug(
                      "hide iframe id {0}"
                      , frameId);
                      * Calls a function of the specified name defined on the IFrame document
                      * (like document.functionName = function () {...} ), passing it an array of arguments.
                      * May not work if the iframe contents are in a different domain due to security.
                      * If the frame contents are loaded when this method is called, it will return any
                      * results from the function immediately to the caller (as well as to the callback
                      * function, if defined). Otherwise, the call will be queued, this method will return
                      * null, and results will be passed to the callback function after the frame loads
                      * and the queued function call executes.
                      * @param functionName String Name of function to call
                      * @param args Array List of arguments to pass as an array
                      * @param callback Function to call (if any) with results of IFrame function execution
                      public function callIFrameFunction(functionName:String, args:Array = null, callback:Function = null
                      ):String
                      if
                      (!source)
                      throw new Error("No iframe to call functions on"
                      if
                      (iframeContentHost != appHost)
                      var msg:String = "Warning: attempt to call function "
                      + functionName +
                      " on iframe " + frameId + " may fail due to cross-domain security."
                      logger.debug(msg);
                      if
                      (frameLoaded)
                      // Call the function immediately
                      var result:Object = ExternalInterface.call("callIFrameFunction"
                      , iframeId, functionName, args);
                      if (callback != null
                      callback(result);
                      return
                      String(result);
                      else
                      // Queue the function for call once the iframe has loaded
                      var
                      queuedCall:Object = {functionName: functionName, args: args, callback:callback};
                      functionQueue.push(queuedCall);
                      return null
                      // Loading indicator
                      * A UIComponent class to display centered over the iframe container while
                      * the browser is loading its content. Should implement measuredHeight
                      * and measuredWidth in order to be properly sized
                      public var
                      loadIndicatorClass:Class;
                      protected var
                      _loadIndicator:UIComponent;
                      // Overlaying object detection
                      private var overlappingDict:Dictionary = new Dictionary(true
                      private var
                      overlapCount:int = 0;
                      protected function systemManager_addedHandler(event:Event):
                      void
                      // A display object was added somewhere
                      var displayObj:DisplayObject = event.target as
                      DisplayObject;
                      if (displayObj.parent == systemManager && displayObj.name != "cursorHolder"
                      // If the object is a direct child of systemManager (i.e it floats) and isn't the cursor,
                      // check to see if it overlaps me after it's been drawn
                      this
                      .callLater(checkOverlay, [displayObj]);
                      protected function systemManager_removedHandler(event:Event):
                      void
                      // A display object was removed somewhere
                      DisplayObject;
                      if
                      (displayObj.parent == systemManager && overlappingDict[displayObj])
                      logger.debug(
                      "iframe {0} heard REMOVE for {1}"
                      , frameId, displayObj.toString());
                      // If the object is a direct child of systemManager and was an overlapping object, remove it
                      delete
                      overlappingDict[displayObj];
                      if
                      (--overlapCount == 0)
                      visible = validForDisplay;
                      if (displayObj is
                      UIComponent)
                      // Remove listeners for hide and show events on overlappiung UIComponents
                      UIComponent(displayObj).removeEventListener(FlexEvent.HIDE, overlay_hideShowHandler);
                      UIComponent(displayObj).removeEventListener(FlexEvent.SHOW, overlay_hideShowHandler);
                      protected function overlay_hideShowHandler(event:FlexEvent):
                      void
                      DisplayObject;
                      if
                      (event.type == FlexEvent.SHOW && !overlappingDict[displayObj])
                      logger.debug(
                      "iframe {0} heard SHOW for {1}"
                      overlappingDict[displayObj] = displayObj;
                      overlapCount++;
                      visible =
                      false
                      else if
                      (event.type == FlexEvent.HIDE && overlappingDict[displayObj])
                      logger.debug(
                      "iframe {0} heard HIDE for {1}"
                      delete
                      if
                      * Check to see if the given DisplayObject overlaps this object.
                      * If so, add it to a dictionary of overlapping objects and update
                      * this object's visibility.
                      protected function checkOverlay(displayObj:DisplayObject):
                      void
                      if (this
                      .hitTestStageObject(displayObj))
                      logger.debug(
                      "iframe {0} detected overlap of {1}"
                      overlapCount++;
                      visible =
                      false
                      if (displayObj is
                      UIComponent)
                      // Listen for hide and show events on overlapping UIComponents
                      // (ComboBox dropdowns for example aren't removed after use; they're just hidden)
                      UIComponent(displayObj).addEventListener(FlexEvent.HIDE, overlay_hideShowHandler,
                      false, 0, true
                      UIComponent(displayObj).addEventListener(FlexEvent.SHOW, overlay_hideShowHandler,
                      false, 0, true
                      * The native hitTestObject method seems to have some issues depending on
                      * the situation. This is a custom implementation to work around that.
                      * This method assumes that the passed DisplayObject is a direct child
                      * of the stage and therefore has x and y coordinates that are already global
                      protected function
                      hitTestStageObject(o:DisplayObject):Boolean
                      var overlapX:Boolean = false
                      var overlapY:Boolean = false
                      var localMe:Point = new Point(this.x, this
                      .y);
                      var globalMe:Point = this
                      .parent.localToGlobal(localMe);
                      var
                      myLeft:int = globalMe.x;
                      var myRight:int = globalMe.x + this
                      .width;
                      var
                      oLeft:int = o.x;
                      var
                      oRight:int = o.x + o.width;
                      // Does object's left edge fall between my left and right edges?
                      overlapX = oLeft >= myLeft && oLeft <= myRight;
                      // Or does my left edge fall between object's left and right edges?
                      overlapX ||= oLeft <= myLeft && oRight >= myLeft;
                      var
                      myTop:int = globalMe.y;
                      var myBottom:int = globalMe.y + this
                      .height;
                      var
                      oTop:int = o.y;
                      var
                      oBottom:int = o.y + o.height;
                      // Does object's top edge fall between my top and bottom edges?
                      overlapY = oTop >= myTop && oTop <= myBottom;
                      // Or does my top edge fall between object's top and bottom edges?
                      overlapY ||= oTop <= myTop && oBottom >= myTop;
                      return
                      overlapX && overlapY;
                      • 9. Re: Component on page not moving as vertical scroll bar is moved
                        Flex harUI Adobe Employee
                        This component controls an external IFrame which is not part of the Flex layout.  You'll probably have to watch the parent for SCROLL events and move the IFrame.
                        Alex Harui
                        Flex SDK Developer
                        Adobe Systems Inc.
                        Blog: http://blogs.adobe.com/aharui
                        • 10. Re: Component on page not moving as vertical scroll bar is moved
                          This sounds like my solution, any suggested websites (url's) that might show some sample code
                          on helping me implement this.
                          Thanks in advance,
                          Wes
