9 Replies Latest reply on Sep 21, 2009 2:58 AM by ChocoboKnight
    Export indd file to Snippets [VBS]
    ChocoboKnight
      Hello all i'm trying to modify an existing script that Exports indd files to pdf's. it goes through all the indd file and createsa pdf one page at a time and workds fine. However in converting it to do the same but convert to Snippet files  i'm having problems with the "idExportFormat.idInDesignSnippet" class and memebers  when i try somthing like
      myFilePath = myFolderName & "\" & myPageName & "_" & myBaseName & ".inds"
      myDocument.Export idExportFormat.idInDesignSnippet, myFilePath, False
      I get an "The Specified object to does support the desired export format." error # 25398
      if i remove the  ",myflePath, False" then i get a "Missing required parameter 'To' for export event".
      The really anying this is if i change that to a
      myFilePath = myFolderName & "\" & myPageName & "_" & myBaseName & ".xml"
      myDocument.Export idExportFormat.idXML, myFilePath, False
      it works fine..
      So there is somthing missing for the snippet export.
        • 1. Re: Export indd file to Snippets [VBS]
          There is nothing missing, I think. Can you export an entire document to a snippet in the user interface?
          Try your script with a selection of objects instead.
          • 2. Re: Export indd file to Snippets [VBS]
            ChocoboKnight Level 1
            No still having the same problem no what select or don't select.
            • 3. Re: Export indd file to Snippets [VBS]
              I've been looking at the problem in more detial.
              Some of the Export formats requrie presents to be set such as the EPS "EPSExportPreferences" JPG "JPEGExportPreferences" etc etc, which are in the Application class however there is no Export Preferences memebers for an InDesignSnippet....
              Does anybody have any details about this?
              • 4. Re: Export indd file to Snippets [VBS]
                I've broken the problem down and started as small as possible.
                To do the same thing but to export each page as a jpg's i can use the following script
                Set myInDesign = CreateObject("InDesign.Application.CS3")
                myFile = "c:\myTestFile.jpg"
                myInDesign.ActiveDocument.Export idExportFormat.idJpg, myFile, False
                If i change that round a abit to customize it to export as inds snippets i would get
                myFile = "c:\myTestFile.inds"
                myInDesign.ActiveDocument.Export idExportFormat.idInDesignSnippet, myFile, False
                This produces the following error " The specified object does not support the desired export format"  - Line 3
                This is because the object i am speifiying is "ActiveDocument" which when selected (manually) cannot be exported as a Snippet.
                What I need to do is cycle trough my pages selecting Texframes of which they are multiple on each page and export them as Snippets.
                Can anyone help please?
                • 5. Re: Export indd file to Snippets [VBS]
                  Hello all,
                  I've been doing some digging over the past few days and looking at Samples and other peoples questions/answers/scripts and i haven't seen any scripts where textframes have been selected which what i beleive i need to do. My question is. Is it even possible to select textframes if it is could someone tell me how if it isn't or i'm barking up the wrong tree could somone point me in the right direction please.
                  • 6. Re: Export indd file to Snippets [VBS]
                    Nobody has anything to say about this?
                    • 7. Re: Export indd file to Snippets [VBS]
                      AdobeScripts Level 3
                      hi
                      here is example for iterating trough all TFs on all Pages:
                      For a=1 to myDoc.Pages.Count
                        Set myPage=myDoc.Pages.Item(a)
                        For b=1 to myPage.TextFrames.Count
                          Set myTextFrame=myPage.TextFrames.Item(b)
                          Call myInDi.Select(myTextFrame)
                        Next
                      Next
                      robin
                      www.adobescripts.co.uk
                      • 8. Re: Export indd file to Snippets [VBS]
                        Thank you for your help.
                        • 9. Re: Export indd file to Snippets [VBS]
                          I've cracked it! thanks to Jongware for his input and a Maximum thanks to Robert-Tkaczyk for his input. here's the Script for all you googlers who need it!
                          Set myFileSystemObject = CreateObject("Scripting.FileSystemObject")
                          If myInDesign.Documents.Count <> 0 Then
                          Set myDocument = myInDesign.ActiveDocument
                          Rem VBScript doesn’t have a native "get folder" statement, so we’ll use
                          Rem InDesign’s JavaScript to display a folder browser.
                          myJavaScript = "myFolder = Folder.selectDialog(""Choose a Folder"");myFolderName = myFolder.fsName;"
                          Rem Run the string "myJavaScript" as a JavaScript
                          myFolderName = myInDesign.DoScript(myJavaScript,idScriptLanguage.idJavascript)
                          If myFileSystemObject.FolderExists(myFolderName) Then
                          myExportPages myInDesign, myDocument, myFolderName
                          End If
                          End If
                          Function myExportPages(myInDesign, myDocument, myFolderName)
                          myDocumentName = myDocument.Name
                          Set myDialog = myInDesign.Dialogs.Add
                          With myDialog
                            .Name = "ExportAllPagesToPDF"
                            With .DialogColumns.Add
                            With .DialogRows.Add
                              With .StaticTexts.Add
                              .StaticLabel = "Base Name:"
                            End With
                            Set myBaseNameField = .TextEditboxes.Add
                            myBaseNameField.EditContents = replace(myDocumentName,".indd","")
                            myBaseNameField.MinWidth = 160
                            End With
                              End With
                          End With
                          myResult = myDialog.Show
                          If myResult = True Then
                          myBaseName = myBaseNameField.EditContents
                          Rem Remove the dialog box from memory.
                          myDialog.Destroy
                          For myCounter = 1 To myDocument.Pages.Count
                          myPageName = myDocument.Pages.Item(myCounter).Name
                          myInDesign.PDFExportPreferences.PageRange = myPageName
                          myInDesign.PDFExportPreferences.CropMarks = True
                          Rem Generate a file path from the folder name,
                          Rem the base document name, and the page name.
                          Rem Replace the colons in the page name (e.g., "Sec1:1") with
                          Rem underscores.
                            Set myPage=myDocument.Pages.Item(myCounter)
                              Call myInDesign.Select(myTextFrame)
                          Set myTF = myDocument.TextFrames.Item(1)
                            myPageName = Replace(myPageName, ":", "_")
                            myFilePath = myFolderName & "\" & myPageName & b & "_" & myBaseName & ".inds"
                            myTextFrame.Export idExportFormat.idInDesignSnippet, myfilepath , false
                          Next
                          'Next
                          Next
                          Else
                          myDialog.Destroy
                          End If
                          End Function
