0 Replies Latest reply on Aug 28, 2009 10:04 AM by Paul Reilly
    [svn:fx-trunk] 9753: * Implemented support for setting the SWF and HTML backgroundColor via
    Paul Reilly Level 1
      Revision: 9753
      Author:   preilly@adobe.com
      Date:     2009-08-28 10:03:40 -0700 (Fri, 28 Aug 2009)
      Log Message:
      • Implemented support for setting the SWF and HTML backgroundColor via
        CSS.  This is part of the "More styles for Spark skins" feature.
      QE notes: See me for a suggested testing matrix.
      Doc notes: SWF and HTML backgroundColor can be set via CSS now.
      Bugs: SDK-22659
      Reviewer: Pete F.
      Tests run: checkintests, mustella tests/Application
      Is noteworthy for integration: yes, should help unblock "MX Only"
      Code-level description of changes:
        flex2/tools/PreLink.java
          Modified processMainUnit() to call lookupBackgroundColor() if the
          backgroundColor hasn't been set inline.
          Added lookupBackgroundColor(),
          lookupTypeSelectorBackgroundColor(),
          lookupClassSelectorBackgroundColor(), and lookupStyleName().
        flex2/compiler/CompilationUnit.java
          Added styleName variable for holding a potential inline styleName
          value.
        flex2/compiler/as3/EmbedExtension.java
          Modified generate() to format the className before calling getClass().
        flex2/compiler/css/StyleModule.java
          Added getStyleDef().
        flex2/compiler/css/StyleDef.java
          Changed styles from List.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22659
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flash/css/StyleDeclaration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilationUnit.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/EmbedExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleModule.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/DocumentBuilder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
