6 Replies Latest reply on Aug 3, 2011 5:46 PM by fahnesjh
    1180: Call to a possibly undefined method dispatchEvent - NOT static function
    d:n:k
      Hi there... I am trying to fire an event from a model...
      <code>
      package testapp.mate.models
          import mx.collections.ArrayCollection;
          import testapp.mate.events.*;
          import flash.events.Event;
          public class AppModel
              [Bindable(event="getNameEvent")]
              public var name:String;
              [Bindable(event="getEmailEvent")]
              public var email:String;
              [Bindable(event="onFireEvent")]
              public var wasFired:String;
              [Bindable(event="testDgEvt")]
              public var dgGrid:ArrayCollection;
              public function AppModel()
              public function storeName(namein:String):void
                  this.name = namein;
                  var getNameEvt:EchoEvent = new EchoEvent(EchoEvent.GET_NAME_EVENT);
                  dispatchEvent(getNameEvt);
              public function storeEmail(emailin:String):void
                  this.email = emailin;
                  var getEmailEvt:EchoEvent = new EchoEvent(EchoEvent.GET_EMAIL_EVENT);
                  dispatchEvent(getEmailEvt);
              public function storeWasFiredStatus(statusin:String):void
                  this.wasFired = statusin;
                  var getFiredEvt:EchoEvent = new EchoEvent(EchoEvent.ON_FIRE_EVENT);
                  dispatchEvent(getFiredEvt);
              public function storeDg(dg:Array):void
                  dgGrid = new ArrayCollection(dg);
                  var getDataEvt:TestDgEvent = new TestDgEvent(TestDgEvent.GET_DATA_EVENT);
                  dispatchEvent(getDataEvt);
      </code>
      Now I keep getting an error:
      "1180: Call to a possibly undefined method dispatchEvent."
      Now from what I have been googling, this comes up a lot if a function is static. However mine is not.
      Ideas?
      D
        • 1. Re: 1180: Call to a possibly undefined method dispatchEvent - NOT static function
          Gregory Lafrance Level 6
          Your class does not have a dispatchEvent() method. If you intend to use the Flex dispatchEvent() method simply extend UIComponent:
          public class AppModel extends UIComponent
          You will need to import mx.core.UIComponent.
          If this post answered your question or helped, please mark it as such.
          • 2. Re: 1180: Call to a possibly undefined method dispatchEvent - NOT static function
            d:n:k Level 1
            I did that, and now i have another error:
            1152: A conflict exists with inherited definition flash.display:DisplayObject.name in namespace mx.core:IFlexDisplayObject public.
            here is what i have for code now:
            <code>
                import mx.core.UIComponent;
                        this.name = namein;
            </code>
            • 3. Re: 1180: Call to a possibly undefined method dispatchEvent - NOT static function
              msakrejda Level 4
              Your model should probably not extend UIComponent (since it's not really a UI component; it's a model). If you'd like event dispatch from your model, extend EventDispatcher itself.
              Maciek Sakrejda
              Truviso, Inc.
              www.truviso.com
              Truviso is hiring: http://www.truviso.com/company-careers.php?i=87
              • 4. Re: 1180: Call to a possibly undefined method dispatchEvent - NOT static function
                Barna Biro Level 3
                Yes, extending EventDispatches is way better then extending UIComponent. Beside that, I have no idea why are you declaring bindable objects. You are just creating an unnecessary overhead with no benefit. Also, why aren't you simply defining a protected/private variable of type EchoEvent and reuse it instead of instantiating the EchoEvent each time with a different reference...
                • 5. Re: 1180: Call to a possibly undefined method dispatchEvent - NOT static function
                  d:n:k Level 1
                  I had gone this way due to a recommendation (on a different forum post) for another issue I was having (bindings not updating). I was not sure why I had to do it this way, but in working through it all, and this was the code I came up with. Now in all honsty, I had taken the code backwards and gotten rid of all of this. My original issue was becasue I was clearing a text field, instead of clearing the var in my data model... so binding wasn't working for the next call. Anywys - that is OT as it is what led to this issue. Either way, I have stripped out this code, and it is a moot point (for me).
                  I wanted to thank all for the ansers and help though.
                  Message was edited by: d:n:k
                  • 6. Re: 1180: Call to a possibly undefined method dispatchEvent - NOT static function
                    fahnesjh Level 1
                    I had the same issue when using dipatchEvent in a class that wasn't extending a specific display object like a MovieClip or a Sprite once the class was extended the dipatchEvent worked. Not sure why.
