• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
spaces in front of form entry values
New Here ,
Apr 24, 2007 Apr 24, 2007
I have a form that submits to itself. After submiting the form, and if there is a user error, the form entry values are brought back with a space in front of the value. For example the first three digits of a ssn number bring back a space + 428.
Is there a way to keep the values from coming back with a space in front?
TOPICS
Advanced techniques
Views
708
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate ,
Use the Trim function, which trims white space.
In a form field, it might look something like this:
<cfoutput>
<input type="text" name="myField" value='#Trim(myValue)#"/>
</cfoutput>
HTH!
Votes
Translate
Translate
Report
Report
New Here ,
I am already using the trim function. There is still a space in front of the entries after the page reloads. It may have something to do with browsers.
Votes
Translate
Translate
Report
Report
Advocate ,
Have you tested with IE and Firefox? If it happens with both browsers, that it probably is not a browser issue.
I've noticed CF places spaces sometimes when I'm calling user defined functions (UDF) and outputing the results to the screen instead of saving the value to a variable. Do you do any UDF processing of your form data?
Votes
Translate
Translate
Report
Report
New Here ,
I am not using many udf. Sample of form entry code below:
<input name="ssn1" type="text" id="ssn1" <cfif isdefined("form.ssn1")> value = "<cfoutput> #form.ssn1#</cfoutput>" <cfelse> value = "<cfoutput>***</cfoutput>"</cfif> onKeyUp ="validotherssn(this);" size="3" maxlength="3" align="left" onKeypress="if (event.keyCode < 48 || event.keyCode > 57 ) event.returnValue = false;" >
<input name="ssn2" type="text" id="ssn2" <cfif isdefined("form.ssn2")>value = "<cfoutput> #form.ssn2#</cfoutput>"<cfelse> value = "<cfoutput>**</cfoutput>" </cfif>
size="2" maxlength="2" onkeyup="validotherssn(this);" onKeypress="if (event.keyCode < 48 || event.keyCode > 57 ) event.returnValue = false;" >
<input name="ssn3" type="text" id="ssn3" <cfif isdefined("form.ssn3")>value = "<cfoutput> #form.ssn3#</cfoutput>" <cfelse> value = "<cfoutput>****</cfoutput>"</cfif> onKeyUp="validotherssn(this);" size="4" maxlength="4" onKeypress="if (event.keyCode < 48 || event.keyCode > 57 ) event.returnValue = false;" > </td>
Votes
Translate
Translate
Report
Report
Guest
If you are already doing a Trim( ), perhaps the "space" is some other non-printing character - a tab, cr, lf, etc. Do an Asc(Left(form.ssn1)) and see what the ASCII character is.
And you don't need all those <CFOUTPUT></CFOUTPUT> in your code. It clutters up the landscape and makes it difficult to read. <CFOUTPUT> at the beginning and </CFOUTPUT> at the end will do the job just fine.
Votes
Translate
Translate
Report
Report
New Here ,
I wrote the following code in the form. Return value was 52. I entered 425 as the value of ssn1.
<cfif isdefined("form.ssn1")><CFOUTPUT>#Asc(Left(form.ssn1,1))#</CFOUTPUT> </cfif>
Votes
Translate
Translate
Report
Report
Advocate ,
Apr 25, 2007 Apr 25, 2007
I think your problem is the space between <cfoutput> and your actual SSN
Try this:
"<cfoutput>#myVar#</cfoutput>"
instead of "<cfoutput> #myVar# </cfoutput>
Or better yet, surround the whole <td> with <cfoutput> so you don't have to keep reusing cfoutput blocks.
Votes
Translate
Translate
Report
Report
Guest
LATEST
> the value of ssn1.
> </cfif>
Then the first character of form.ssn1 is a 4, not a space or other non-printable character. And I agree with insuractive, the space after <CFOUTPUT> is probably giving you problems.
Votes
Translate
Translate
Report
Report
Resources
Documentation
