I'm really confused. I've imported numerous RH5 projects into RH8, and another one that was the published help topics that were created in RH7.
These projects have a 3-pane view that I've taken for granted:
Toolbar (the one that spans the width of a page) typically has the product logo built in, with 3 or 4 nav buttons on the left and the Info button on the far right The info button opens a dialog box I use to identify company info)
T O O L B A R B A N N E R
TOC1 Topic Title
TOC2
TOC3 Narrative text and pictures
TOC4 about the topic
My latest import, though, has only 2 panes....the TOC pane and the toolbar buttons are stuffed into a grey area at the top.
How do I change this behavior? I'm looking at the WebHelp Skin Editor. I imported the skins from 2 of the previous projects, but none of my antics seem to get the top frame to appear. I don't see any "framesets" to import from the other projects. Why am I unable to get the 3 frame-frameset into this project?
I even created a brand new project using the RH HTML (webhelp) wizard and, unfortunately, it also has only the 2 frames. The "top frame" in the WebHelp Skin Editor view somehow gets stuffed into the little nav area at the top of the TOC frame.
here's the problem (created in RH8) http://docs.ubmatrix.com/webhelp/XDA/1_0_1/default.htm
here's the old one (created in RH7...or possibly RH5) http://docs.ubmatrix.com/webhelp/XDA/1_0/Default.htm
Hi there
Likely you have either
I vote for the 508 setting. Edit the Single Source Layout recipe and ensure Section 508 is not enabled.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Hi there
Cheers... Rick
I vote for "and another one that was the published help topics that were created in RH7."
The key word there is "published;" you must import source files, not output files. Sorry.
Leon
RoboWizard was right! The Section 503 WAS set; when it was cleared the top frame reappeared. THANKS!
Leon, this problem didn't occur in or pertain to the mess I'm cleaning up with the 'published file set'.
Thanks SuperMan!
