7 Replies Latest reply on Aug 30, 2009 10:09 PM by manofspirit
    E4X with variables ?
    manofspirit Level 1
      Hello guys
      lets suppose i have an xml as following
      var xml:XML =
      <data>
           <boys>
                <boy name="john"/>
                <boy name="smith"/>
           </boys>
           <girls>
                <girl name="sara"/>
                <girl name="maya"/>
           </girls>
      </data>
      i can do like this
      var guys:XMLList = xml..boys.*;
      var gals:XMLList = xml..girls.*;
      How can i do the samething with a given variable like
      var choice:String = "boys";
      var guys:XMLList = xml..choice.*;
      Thanks in advance
        • 1. Re: E4X with variables ?
          MoonlightWare Level 1
          Try replacing
          with
          var guys:XMLList = xml..[choice].*;
          • 2. Re: E4X with variables ?
            manofspirit Level 1
            Thanks for the reply
            But It raises compile time error.
            Any other way to do that?
            • 3. Re: E4X with variables ?
              Andrew Rosewarn Level 3
              Hi there
              I've made a slight change to the structure of your xml but this will achieve the result you want.  I hope this helps.
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
              <mx:Script>
                   <![CDATA[
                        private var xmlData:XML =
                            <people>
                                <person name='John'>
                                   <gender>Boy</gender>
                                    </person>
                                <person name='Smith'>
                                </person>
                                <person name='Sarah'>
                                    <gender>Girl</gender>
                               </person>
                              <person name='Maya'>
                               </person>
                            </people>;
                   private function handleSelection():void {
                        var choice:String = combo.selectedItem.toString();
                        var selectedXML:XMLList = xmlData.person.(gender == choice);
              </mx:Script>
                   <mx:ComboBox id="combo" x="77" y="74" dataProvider="['Boy','Girl']"></mx:ComboBox>
                   <mx:Button x="157" y="74" label="Select" click="handleSelection()"/>
              </mx:Application>
              Andrew
              • 4. Re: E4X with variables ?
                Or optionally a bit shorter on the xml front defining gender as an attribute and using the @ symbol in the e4X
                <mx:Script>
                     <![CDATA[
                              <people>
                                 <person name='John' gender='Boy'/>
                                 <person name='Smith'gender='Boy'/>
                                 <person name='Maya' gender= 'Girl'/>
                              </people>;
                          var selectedXML:XMLList = xmlData.person.(@gender == choice);
                </mx:Script>
                </mx:Application>
                Andrew
                • 5. Re: E4X with variables ?
                  Barna Biro Level 3
                  @ Andrew: you're overcomplicating it without too much sense.
                  package
                      import flash.display.Sprite;
                      public class XMLExample extends Sprite
                          private var _xml:XML = <data>
                                                      <boys>
                                                           <boy name="john"/>
                                                           <boy name="smith"/>
                                                      </boys>
                                                      <girls>
                                                           <girl name="sara"/>
                                                           <girl name="maya"/>
                                                      </girls>
                                                 </data>;
                          public function XMLExample()
                              var choiceXMLList:XMLList = _xml.child(choice).children();
                  Simply use the child(); and children(); methods to return the desired data.
                  With best regards,
                  Barna Biro
                  • 6. Re: E4X with variables ?
                    Barna
                    Yep thats cool hadn't looked at the child / children methods.
                    Much cleaner.
                    Andrew
                    • 7. Re: E4X with variables ?
                      manofspirit Level 1
                      Thanks a lot Barna and Andrew
