3 Replies Latest reply on Sep 1, 2009 6:16 AM by nagasreekrishna
    how do i change the cell color of each cell in datagrid dynamically
    nagasreekrishna
      I have a  datagrid filled in with data..My job is to change the cell color of a particular cell in the datagrid when the user clicks that cell..Please help me asap..I have to change the color of each cell dynamically..
        • 1. Re: how do i change the cell color of each cell in datagrid dynamically
          Andrew Rosewarn Level 3
          Hi There
          Try the example below it uses an item renderer and some logic inside it to decide what the condition of the data is and then change the color.  In my example if the value of the data is 5 it changes the color.
          The only way I can see to do this is to use an item renderer for your cells.  This is really scruffy and would need tyding up, and maybe with a little more time could do better or someone else may have an idea but none the less this works.
          Define a custom component as below;
          This has logic to see what the value of the data is proveided by the dataprovider for the row, and if it matches the conditions in this case is equal to 5 sets the background color.
          <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml" width="88" height="26" dataChange="doColor()" borderColor="#000000" borderStyle="solid"
              backgroundAlpha="1">
              <mx:Script>
                  <![CDATA[
                      private function doColor():void {
                          if (data.value == 5) {
                              setStyle('backgroundColor', 0xcccccc);
                          } else {
                              setStyle('backgroundColor', 0xffffff);
              </mx:Script>
          </mx:Canvas>
          Now just apply the item renderer in the datagrid and that will do it.
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"  xmlns:ns1="*">
              <mx:Script>
                  <![CDATA[
                      import mx.collections.ArrayCollection;
                      [Bindable]
                      private var ac:ArrayCollection = new ArrayCollection([
                          {value : 1},
                          {value : 2},
                          {value : 3},
                          {value : 4},
                          {value : 5},
                          {value : 6},
                          {value : 7},
                          {value : 8},
                          {value : 9},
                          {value : 10}
              </mx:Script>
              <mx:DataGrid x="40" y="36" width="408" height="193" dataProvider="{ac}">
                  <mx:columns>
                      <mx:DataGridColumn headerText="Column 1" dataField="value" itemRenderer="MyComp"/>
                      <mx:DataGridColumn headerText="Column 2" dataField="col2"/>
                      <mx:DataGridColumn headerText="Column 3" dataField="col3"/>
                  </mx:columns>
              </mx:DataGrid>
          </mx:Application>
          I hope this helps if you don;t understand any of it please ask.
          Andrew
          • 2. Re: how do i change the cell color of each cell in datagrid dynamically
            ShardulSingh Level 3
            Pls find the solution of ur problem.Let me know if you have any issue.
            MainApplicaion.mxml
                layout="vertical">
                <mx:Script>
                    <![CDATA[
                        import mx.events.ListEvent;
                        [Bindable]
                          private var listDataArrayCollection:ArrayCollection=
                            {seq:'1',color:'0xFF0000', names:'John'},
                            {seq:'2',color:'0x00FF00', names:'Alex'},
                            {seq:'3',color:'0x0000FF', names:'Peter'},
                            {seq:'4',color:'0xFF0000', names:'Sam'},
                            {seq:'5',color:'0x00FF00', names:'Alis'},
                            {seq:'6',color:'0x0000FF', names:'Robin'},
                            {seq:'7',color:'0xFF0000', names:'Mark'},
                            {seq:'8',color:'0x00FF00', names:'Steave'},
                            {seq:'9',color:'0x0000FF', names:'Fill'},
                            {seq:'10',color:'0xFF0000', names:'Abraham'},
                            {seq:'11',color:'0x00FF00', names:'Hennery'},
                            {seq:'12',color:'0x0000FF', names:'Luis'},
                            {seq:'13',color:'0xFF0000', names:'Herry'},
                            {seq:'14',color:'0x00FF00', names:'Markus'},
                            {seq:'15',color:'0x0000FF', names:'Flip'},
                            {seq:'16',color:'0xFF0000', names:'John_1'},
                            {seq:'17',color:'0x00FF00', names:'Alex_1'},
                            {seq:'18',color:'0x0000FF', names:'Peter_1'},
                            {seq:'19',color:'0xFF0000', names:'Sam_1'},
                            {seq:'20',color:'0x00FF00', names:'Alis_1'},
                            {seq:'21',color:'0x0000FF', names:'Robin_1'},
                            {seq:'22',color:'0xFF0000', names:'Mark_1'},
                            {seq:'23',color:'0x00FF00', names:'Steave_1'},
                            {seq:'24',color:'0x0000FF', names:'Fill_1'},
                            {seq:'25',color:'0xFF0000', names:'Abraham_1'},
                            {seq:'26',color:'0x00FF00', names:'Hennery_1'},
                            {seq:'27',color:'0x0000FF', names:'Luis_1'},
                            {seq:'28',color:'0xFF0000', names:'Herry_1'},
                            {seq:'29',color:'0x00FF00', names:'Markus_1'},
                            {seq:'30',color:'0x0000FF', names:'Flip_2'}
                        private function onItemClick(event : ListEvent):void
                            var dataObj : Object = event.itemRenderer.data;
                            dataObj.color = "0xFF00FF";
                            event.itemRenderer.data = dataObj;
                </mx:Script>
                <mx:VBox width="300" height="100%"
                    horizontalAlign="center"
                    verticalAlign="middle">
                    <mx:DataGrid id="listComponent" width="50%"
                             height="100%"
                             borderStyle="none"
                             dataProvider="{listDataArrayCollection}"
                             itemClick="onItemClick(event)">
                             <mx:columns>
                             <mx:DataGridColumn width="100" dataField="{data.seq}" headerText="Seq" itemRenderer="SeqItemRenderer" />
                             <mx:DataGridColumn width="100" dataField="{data.names}" headerText="Name" itemRenderer="NameItemRenderer"/>
                             </mx:columns>
                             </mx:DataGrid>
                </mx:VBox>
            </mx:Application
            NameItemRenderer.mxml
            <mx:HBox xmlns:mx="http://www.adobe.com/2006/mxml"
                width="100" height="30" horizontalGap="5" horizontalScrollPolicy="off">
            <mx:Script>
                <![CDATA[
                    override public function set data(value:Object):void
                         super.data = value;
            </mx:Script>
                    <mx:TextInput width="75" height="30"
                         text="{data.names}"
                         editable="false" backgroundColor="{data.color}"/>
                </mx:HBox>
            SeqItemRenderer.mxml
            <mx:Script>
                <![CDATA[
                         super.data = value;
            </mx:Script>
                         text="{data.seq}"
                </mx:HBox>
            with Regards,
            Shardul Singh Bartwal
            • 3. Re: how do i change the cell color of each cell in datagrid dynamically
              nagasreekrishna Level 1
              <mx:Label xmlns:mx="http://www.adobe.com/2006/mxml"
                  preinitialize="initTA();">
              <mx:XML id="myXml" source="items.xml" />
                  <mx:Script>
                      <![CDATA[
                          public function initTA():void {
                              addEventListener(MouseEvent.CLICK,setColor);
                 public function setColor():void{
                        this.opaqueBackground=0xbf2222;
                  </mx:Script>
              </mx:Label>
              I have set this as ItemRenderer to my DataGrid..and it worked....If user clicks on the cell of the DataGrid its color changes
              Thank you very much for the replies...
