3 Replies Latest reply on Jul 26, 2008 9:31 AM by Newsgroup_User
    Dw2004 templates
    Level 7
      No doubt Murray will be along shortly - and what he doesn't know about
      templates probably isn't worth knowing
      My friend who has only just upgraded to CS3, in common with many
      others didn't seem to know that it's possible and highly desirable to
      have the meta description tag in the "InstanceBeginEditable
      name="head" " region.
      This is what he said: - I'm 95% sure he is incorrect and probably set
      up the templates incorrectly - a common mistake we see a lot here.
      "The main reason I've had duplicate meta description tags is that DW
      MX2004 does not allow meta tags in editable regions of templates. I've
      now discovered that this also applies to templates created in MX2004
      when edited in CS3. You can add them to the template but they just do
      not appear on the pages."
      Any comments ?
      ~Malcolm~*...
        • 1. Re: Dw2004 templates
          Level 7
          Your friend is smoking crack, so to speak.
          Completely wrong.
          > I've now discovered that this also applies to templates created in MX2004
          > when edited in CS3.
          Even wronger.
          What is his procedure for demonstrating this? And by the way, the Template
          engine in MX2004 is the same as the one in MX and in CS3, so nothing has
          changed over that span of versions.
          > name="head" region.
          Precisely.
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "Malcolm _" <malcom@mon.org> wrote in message
          news:77ul84d4r9utqogp39nfuhbqri2jcdsotl@4ax.com...
          > Any comments ?
          > ~Malcolm~*...
          • 2. Re: Dw2004 templates
            Level 7
            On Sat, 26 Jul 2008 07:48:53 -0400, "Murray *ACE*"
            >Completely wrong.
            Many thanks for confirming what I was 95% certain of myself.
            I've passed on your message and will see what the response is -;)
            ~Malcolm~*...
            • 3. Re: Dw2004 templates
              Level 7
              Maybe he could share some of his stash if nothing else....
              news:gujm84tupugrkh1umeu3hnoqaetal3ebcm@4ax.com...
              >>Completely wrong.
              > ~Malcolm~*...
