3 Replies Latest reply on Aug 31, 2009 12:09 AM by msabljic
    Simple chart data tip question
    msabljic Level 1
      If i have a graph with let's say month names on x-axis and some numeric values on y-axis, when over specific chart item tooltip displays both month name and numeric value. How can i achive that tooltip displays only let's say numeric value (y-axis value) and not also month name (x-axis value)?
      Thanks in advance,
      Best regards
        • 1. Re: Simple chart data tip question
          chris.huston.t10 Level 3
          You can use a dataTipFunction to customize the chart data tip.
          private function myDataTipFxn(hd:HitData):String {
               var dt:String = "y value = " + hd.item.yourYvalueField;
               return dt;
          Chris
          • 2. Re: Simple chart data tip question
            Andrew Rosewarn Level 3
            Yes as above and as below.  Calling you dataTipFunction from the Chart tag, whatever type of chart it may be.
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" >
                <mx:Script>
                    <![CDATA[
                    import mx.charts.HitData;
            import mx.collections.ArrayCollection;
                    [Bindable]
                    private var expensesAC:ArrayCollection = new ArrayCollection( [
                        { Month: "Jan", Profit: 2000, Expenses: 1500, Amount: 450 },
                        { Month: "Feb", Profit: 1000, Expenses: 200, Amount: 600 },
                        { Month: "Mar", Profit: 1500, Expenses: 500, Amount: 300 },
                        { Month: "Apr", Profit: 1800, Expenses: 1200, Amount: 900 },
                        { Month: "May", Profit: 2400, Expenses: 575, Amount: 500 } ]);
                                var dt:String = "Profit = " + hd.item.Profit;
                                return dt;
                </mx:Script>
                <mx:LineChart id="linechart" color="0x323232" height="259"
                   showDataTips="true" dataProvider="{expensesAC}"
                   dataTipFunction="myDataTipFxn" x="88.5" y="63">
                   <mx:horizontalAxis>
                       <mx:CategoryAxis categoryField="Month"/>
                   </mx:horizontalAxis>
                   <mx:series>
                       <mx:LineSeries yField="Profit" form="curve" displayName="Profit"/>
                       <mx:LineSeries yField="Expenses" form="curve" displayName="Expenses"/>
                       <mx:LineSeries yField="Amount" form="curve" displayName="Amount"/>
                   </mx:series>
                </mx:LineChart>
            </mx:Application>
            • 3. Re: Simple chart data tip question
              msabljic Level 1
              Thank you guys for help and examples, very useful.
              Best regards
