7 Replies Latest reply on Aug 31, 2009 10:18 AM by proenza
    motion tracking and masks
    proenza Level 1
      i'm getting stuck here.
      i know that one time i made a motion tracking and use a mask without to keyframe manually.
      i have a movie clip with one guy walking and i motion tracked that, after, applied data to a null
      i had a layer bellow with the background empty so when i use the mask over his head, it seems he doesnt have the head. but now i can't put the data on the mask. and i know i did that last year in aftereffects, without scripts. i used copy/paste frames or the expression on mask path linking to position keyframes of the null
      i know i did that in cs3, but in cs4 i cant
      i think that already dont have the project that i made last year
      any thoughts?
        • 1. Re: motion tracking and masks
          yenaphe Adobe Community Professional
          What if you copy your mask on a solid, then link the solid to the tracked null and use it as a trackmatte ?
          • 2. Re: motion tracking and masks
            proenza Level 1
            it doesnt work
            • 3. Re: motion tracking and masks
              Adolfo Rozenfeld Adobe Employee
              Why doesn't it work?
              • 4. Re: motion tracking and masks
                Please be more specific. While we all appreciate short and to the point postings, nobody can guess your issue. "My car doesn't run" type of posts are never a good way to get qualified help. Post a screenshot or describe more clearly what exactly you are doing/ intend to do!
                • 5. Re: motion tracking and masks
                  You can't apply tracking data directly to a mask without a script. You can apply tracking data to a layer that contains a mask and use that layer as a track matte.
                  Tracking data looks like this:
                  Adobe After Effects 8.0 Keyframe Data
                  Units Per Second 29.97
                  Source Width 720
                  Source Height 540
                  Source Pixel Aspect Ratio 1
                  Comp Pixel Aspect Ratio 1
                  Transform Position
                  Frame X pixels Y pixels Z pixels
                  7 361.799 270.452 0
                  8 364.354 276.231 0
                  9 365.084 280.343 0
                  10 364.487 282.402 0
                  End of Keyframe Data
                  Mask data  isn't about pixels, it's about vectors, vertex position, angles, bezier curves. There are a few scripts out there that let you attach position data to vertex position but that's it. If you want to track and mask the best option is the Mocha Shape plug-in.
                  If you simply  want to move the layer with the mask then you can either copy and paste the keyframe data from the feature center or attach point to the position property of the layer.  You can't just select the feature center and paste to the layer. You'll end up with Tracker 1 Track point 1 keyframes which are not attached to any transform property of the layer. It's a common mistake.
                  • 6. Re: motion tracking and masks
                    proenza Level 1
                    reaaly appreciate your help
                    yep i would like just move the mask not the layer, and copy/paste frames did not make what i want.
                    if we could add a property for the mask like position would be great. we just have the mask path not position, thats the problem
                    many thanks Rick!
                    • 7. Re: motion tracking and masks
                      proenza Level 1
                      thanks a lot too, sebastien
                      i meant it works but it gives you other problems
