9 Replies Latest reply on Sep 4, 2009 8:11 AM by klaus musset
    AlternatingFills -> VBA
    klaus musset
      Hello,
      I am using the script of the turorial for alternating rows and get an Error.
      I use:
          myTable.alternatingFills = idAlternatingFillsTypes.idAlternatingRows
          myTable.startRowFillColor = myDocument.swatches.Item("DGC1_446a")    <- here is the Error
          myTable.startRowFillTint = 60
          myTable.endRowFillColor = myDocument.swatches.Item("DGC1_446b")
          myTable.endRowFillTint = 50
      and get the message: Error 13, Type mismatch.
      if I iterate thru the rows with the following code, everything works fine, it's just slow:
           For k = 1 To myTable.Rows.Count
              If k Mod 2 = 0 Then
                  myTable.Rows.Item(k).FillColor = myDocument.Swatches.Item("DGC1_446a")
                  myTable.Rows.Item(k).FillTint = 40
              End If
           next k
      Where is the problem
      Thanx for helping
      Klaus
        • 1. Re: AlternatingFills -> VBA
          Harbs. Level 6
          What happens if you first create a reference  to the swatch?
          Harbs
          http://www.in-tools.com
          Innovations in Automation
          • 2. Re: AlternatingFills -> VBA
            klaus musset Level 1
            Hi Harbs,
            thanx for the answer.
            Do you mean:
                myAddColor myDocument, "DGC1_446a", idColorModel.idProcess, Array(0, 100, 0, 50)
                myAddColor myDocument, "DGC1_446b", idColorModel.idProcess, Array(100, 0, 50, 0)
            thats done.
            VBA doesn't seem to accept this value -> idColorModel.idProcess
            By the way, I'm just starting to script ID. It's hard to get any documentation about it.
            Just the sample script from Adobe.
            A lot of stuff is not explained.
            There is no reference, so it's more a hit and miss situation.
            By the way:
            How do you adjust a textframe to the table in the textframe?
            I did it by calculation or is there a shortcut to it?
            Thanx again
            Klaus
            • 3. Re: AlternatingFills -> VBA
              Steven.. Level 3
              If you are using VBA and not VBS then you can't use
              you would have to use the value of the enum
              myTable.alternatingFills = 1097618039
              Steven
              • 4. Re: AlternatingFills -> VBA
                Thanx Steve.
                I tried it. That is not the problem, that works fine.
                The error is created in the line after:
                -> myTable.StartRowFillColor = myDocument.Swatches.Item("DGC1_446a")
                -> Run-time error '13': Type mismatch
                I my script it works on 1 line on the other it doesn't (see below). The swatches are all on CMYK.
                I used the code from the sample script: AlternatingRows.vbs
                This script is not running too?!?
                I guess there is a problem with the colormodel -> RGB vs. CMYK.
                I didn't find any info about that.
                Thanks for helping
                Klaus
                This is the complete part of my script:
                    myAddColor myDocument, "RewaldFarbe", idColorModel.idProcess, Array(19.45, 1.68, 0, 0)
                    If myTable.Rows.Item(1).RowType <> idRowTypes.idHeaderRow Then
                        myTable.Rows.Item(1).RowType = idRowTypes.idHeaderRow
                    End If
                        myTable.Rows.Item(k).MinimumHeight = 2.2
                        myTable.Rows.Item(k).LeftInset = 0
                        myTable.Rows.Item(k).RightInset = 0
                        myTable.Rows.Item(k).TopInset = 0.9
                        myTable.Rows.Item(k).BottomInset = 1
                        If k Mod 2 = 0 Then
                            myTable.Rows.Item(k).FillColor = myDocument.Swatches.Item("RewaldFarbe")  -> This works
                            myTable.Rows.Item(k).FillTint = 100
                        End If
                    Next k
                    myTable.AlternatingFills = 1097618039
                    myTable.StartRowFillColor = myDocument.Swatches.Item("DGC1_446a") -> Here it stops with error
                    myTable.StartRowFillTint = 60
                    myTable.EndRowFillColor = myDocument.Swatches.Item("DGC1_446b")
                    myTable.EndRowFillTint = 50
                • 5. Re: AlternatingFills -> VBA
                  Harbs. Level 6
                  Create a referrence to myDocument.Swatches.Item("DGC1_446a") in a variable "mySwatch" and then try:
                  myTable.StartRowFillColor = mySwatch
                  • 6. Re: AlternatingFills -> VBA
                    Steven.. Level 3
                    I don't know the issue, it works for me. Follow harbs advice so you can break down the error one more step
                    One interesting thing is that startRowFillColor takes a swatch
                    Property StartRowFillColor As Swatch
                        Member of InDesign.TableStyle
                        The fill color, specified as a swatch (color, gradient, tint, or mixed ink), of rows in the first alternating fills group. Note: Valid when alternating fills are defined for table rows.
                    while FillColor takes a variant
                    Property FillColor As Variant
                        Member of InDesign.Cell
                        The swatch (color, gradient, tint, or mixed ink) applied to the fill of the object. Type: Swatch or String
                    Not that it should make a difference
                    • 7. Re: AlternatingFills -> VBA
                      Thanks, you're actually pinpointing the problem:
                      typeName(myDocument.Swatches.Item("None"))
                      return 'Swatch'
                      All other items in the swatch panel fx:
                      typeName(myDocument.Swatches.Item("Black"))
                      return 'Color' or 'Gradient' - depending on how the swatch is designed.
                      Means:
                      myTable.StartRowFillColor = typeName(myDocument.Swatches.Item("None"))
                      Works fine, but
                      Dim mySwatch as InDesign.Swatches
                      set mySwatch = typeName(myDocument.Swatches.Item("Black"))
                      Returns an error because an object is expected.
                      This is strange because 'Swatches.Item("Whatever")' should be a swatch, shouldn't it ?!?
                      The only item in my swatch collection I found to be a swatch was
                      How can you see in the swatch panel, what is a swatch and what isn't?
                      I didn't find a way to add any other items in the swatch panel to the swatch collection.
                      Is there a bug or is there any other way to solve that mystery.
                      By the way: I'm working with the German installation of CS4, but that shouldn't make a difference?!?
                      Thanks for your help
                      Klaus
                      • 8. Re: AlternatingFills -> VBA
                        Harbs. Level 6
                        You don't add swatches. You add colors. Once a named color is added it
                        is a swatch. Kind of confusing, but that's how it works...
                        Harbs
                        • 9. Re: AlternatingFills -> VBA
                          But here seems to be the problem
                          Dim mySwatch1 As InDesign.Swatch
                          Set mySwatch1 = myDocument.Swatches.Item("Black")
                          creates the error 13: Type mismatch
                          Checking
                          typename(myDocument.Swatches.Item("Black")
                          I get 'Color'
                          But as Steven stated
                          myTable.StartRowFillColor = myDocument.Swatches.Item("Black")
                          Doesn't get accepted.
                          As it says: 'The fill color, specified as a swatch'
                          Q: How do you specify fx: 'myDocument.Swatches.Item("Black")' as a swatch?
                          Thanx
                          Klaus
