6 Replies Latest reply on Aug 31, 2009 7:07 AM by Gregory Lafrance
    HTTPService
    Yogi_ACE
      I want to add XML file as dataprovider to charting component. Data should be accessed using HTTP Service. Whenever I use HTTP Service instead of WebService it simply shows me result as "null"
      Can anybody share example or source?
        • 1. Re: HTTPService
          Barna Biro Level 3
          • 2. Re: HTTPService
            Madhav Subedi Level 4
            can you post your source code here?
            • 3. Re: HTTPService
              Yogi_ACE Level 2
              public function init():void{
                   var httpService:HTTPService = new HTTPService();
                   httpService.url = "data/Test.xml";
                   httpService.resultFormat = "e4x";
                   httpService.addEventListener(FaultEvent.FAULT, onFaultHttpService);
                   httpService.addEventListener(ResultEvent.RESULT, onResultHttpService);
                   httpService.send();
              public function onResultHttpService(e:*):void{
                   viewXMLList = new XMLList(e.result);
                   chartDP  = xmlListToObjectArray(viewXMLList);
                   // chart data rendering...
                   chartObj.dataprovider = chartDP;
              I also tryied with object conversion but it always returns null.
              public function xmlListToObjectArray(xmlList:XMLList):ArrayCollection
                   var a:ArrayCollection = new ArrayCollection();
                   var attributes:XMLList = xmlList;
                   var o:Object = new Object();
                   for each (var attribute:XML in attributes)
                        var nodeName:String = attribute.name().toString();
                        var value:* = attribute;
                        o[nodeName] = value;
                   a.addItem(new ObjectProxy(o));
                   return a;
              • 4. Re: HTTPService
                Yogi_ACE Level 2
                Hi Barna,
                I can retrieve the XML, I can also able to get the length but while type conversion it returns null.
                • 5. Re: HTTPService
                  Barna Biro Level 3
                  That might be because you are converting the result to the wrong type.
                  Should be ( the correct type should be XML and not XMLList when you convert the result from the service ):
                  var result:XML = XML(e.result);
                  See if that solves the problem ( once you have the XML structure, you can filter it for whatever data you need and convert those pieces into XMLList if you really want ).
                  EDIT: Although, giving it a better thought, this should work as well: viewXMLList = new XMLList(e.result); ... Did you try checking the value of viewXMLList? If the value is correctly represented then the problem is somewhere else.
                  • 6. Re: HTTPService
                    Gregory Lafrance Level 6
                    Usually you need to go a little deeper into your data your result handler:
                        viewXMLList = new XMLList(e.result..item);
                    if your data was, for example:
                    <data>
                        <item>
                            ... add elements for this item
                        </items>
                        <item>
                        </items>
                        <item>
                        </items>
                    </data>
                    If this post answers your question or helps, please mark it as such.
