1 Reply Latest reply on Aug 31, 2009 4:39 AM by ShardulSingh
    Managing the values of the actual day, month and year
    Augusto Esteves
      I'm trying to get into numeric variables the actual day (format: 1 / 10), month (format: 1 / 10), and year (format: 1900). I tried using this example:
      <mx:DateFormatter id="DDformatter" formatString="DD"/>
      <mx:DateFormatter id="MMformatter" formatString="MM"/>
      <mx:DateFormatter id="YYYYformatter" formatString="YYYY"/>
      Inside the Script:
      private var actualDate:Date = new Date();
      [Bindable] private var actualDay:String = DDformatter.format(actualDate);
      [Bindable] private var actualMonth:String = MMformatter.format(actualDate);
      [Bindable] private var actualYear:String = YYYYformatter.format(actualDate);
      A part from getting an error when I run my application (am I missing some import?) I would like to have this data in numeric variables:
      Error #1009 - Cannot access a property or method of a null object reference.
        • 1. Re: Managing the values of the actual day, month and year
          ShardulSingh Level 3
          Pls find the solution of your problem....let me know if you have any issue.
          MainApplication.mxml
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
          layout="absolute" creationComplete="onCreationComplete()">
          <mx:Script>
          <![CDATA[
          [Bindable]
          private var actualDay:String;
          [Bindable]
          private var actualMonth:String;
          [Bindable]
          private var actualYear:String;
          private function onCreationComplete():void
          actualDay = DDformatter.format(actualDate);
          actualMonth = MMformatter.format(actualDate);
          actualYear = YYYYformatter.format(actualDate);
          </mx:Script>
          <mx:VBox width="500" height="300">
          <mx:HBox>
          <mx:Label width="150" text="Date"/>
          <mx:Label id="dayLbl" text="{actualDay}"/>
          </mx:HBox>
          <mx:HBox>
          <mx:Label width="150" text="Month"/>
          <mx:Label id="monthLbl" text="{actualMonth}"/>
          </mx:HBox>
          <mx:HBox>
          <mx:Label width="150" text="Year"/>
          <mx:Label id="yearLbl" text="{actualYear}"/>
          </mx:HBox>
          </mx:VBox>
          </mx:Application>
          with Regards,
          Shardul Singh Bartwal
