10 Replies Latest reply on Sep 5, 2009 5:45 AM by _Natasha_
    problem in datagrid?
    435.mahesh Level 1
      i have one application and two components
      RolesDatagrid.mxml
      <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml" width="444" height="148">
        <mx:Script>
            <![CDATA[
                import mx.core.IFlexDisplayObject;
                import mx.managers.PopUpManager;
                //import components.RolesTitleWindow;
                public function fnAddRoles():void
                    var var_role_title_window:RolesTitleWindow=RolesTitleWindow(PopUpManager.createPopU p(this,RolesTitleWindow,true));
                      PopUpManager.centerPopUp(var_role_title_window);
        </mx:Script>
          <mx:DataGrid x="0" y="0" width="301" height="94">
              <mx:columns>
                  <mx:DataGridColumn headerText="RoleName"     dataField="col1"/>
                  <mx:DataGridColumn headerText="EmployeeName" dataField="col2"/>
                  <mx:DataGridColumn headerText="Action"       dataField="col3"/>
              </mx:columns>
          </mx:DataGrid>
          <mx:Button x="316" y="72" label="AddRoles" click="fnAddRoles()" styleName="buttonNoOfficial" width="95" height="22"/>
      </mx:Canvas>
      RolesTitleWindow.mxml
      <mx:TitleWindow xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" width="400" height="250">
        <mx:Script>
            <![CDATA[
                public function fnDivisionRoleName():void
        </mx:Script>
          <mx:ArrayCollection id="id_array1">
              <mx:String>mahesh</mx:String>
              <mx:String>suresh</mx:String>
              <mx:String>babu</mx:String>
          </mx:ArrayCollection>
          <mx:ArrayCollection id="id_array2">
              <mx:String>Pm</mx:String>
              <mx:String>Tm</mx:String>
              <mx:String>ssl</mx:String>
          <mx:ComboBox id="id_dividion_role_name" x="48" y="77" width="92" dataProvider="{id_array2}"></mx:ComboBox>
          <mx:ComboBox x="168.5" y="77" width="92" dataProvider="{id_array1}"></mx:ComboBox>
          <mx:Button x="94" y="127" label="Add"  click="fnDivisionRoleName();"/>
          <mx:Button x="168.5" y="127" label="Cancel"/>
      </mx:TitleWindow>
      App.mxml(application)
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" xmlns:local="*">
          <local:RolesDatagrid />
      </mx:Application>
      This is the code.When ren the application u will get datagrid and addRoles button.wen u click on
      the addRoles button u will get title window.It contains two comboboxes and add button.My
      requirement is select values from two comboboxes and click on add button,then the selected combox
      data will be added to datagrid firstrow(It will contains three fields those are rolename,employeename,action).
      For example if u select comboboxes items are pm,mahesh then i want the datagrid items are
      rolename      employeename     action
      pm              mahesh             Edit,delte buttons
      Regards
      D.Mahesh Babu
        • 2. Re: problem in datagrid?
          _Natasha_ Level 4
                       var obj:Object = new Object();
                         obj.col1 = id_dividion_role_name.selectedLabel;
                         obj.col2 = id_employee_name.selectedLabel; // create this id for second combobox
                         // and return this object to dataProvider for DataGrid. The easiest way is to dispatch CloseEvent and read a property.
                  <mx:columns>
                      <mx:DataGridColumn headerText="Action"       dataField="col3">
                         <mx:itemRenderer>
          <mx:Component>
          <mx:VBox>
          <mx:Script>
          <![CDATA[
          private function editFcn(data:*):void
          // edit data
          private function deleteFcn(data:*):void
          // delete data
          </mx:Script>
          <mx:Button label="Edit" click="editFcn(data)"/>
          <mx:Button label="Delete" click="deleteFcn(data)"/>
          </mx:VBox>
          </mx:Component>
          </mx:itemRenderer>
                     </mx:DataGridColumn>
                  </mx:columns>
              </mx:DataGrid>
          • 3. Re: problem in datagrid?
            435.mahesh Level 1
            Thaq natasa.
            If u dont mine can u send me the code for how to send object to dataprovider of
            datadrid of RoleDataGrid.mxml component.
            Regards
            D.Mahesh Babu
            • 4. Re: problem in datagrid?
              _Natasha_ Level 4
              Something like this:
              RolesDatagrid.mxml
                <mx:Script>
                    <![CDATA[
              var_role_title_window.addEventListener(CloseEvent.CLOSE, onWindowClose);
              private functuion onWindowClose(event:CloseEvent):void
                   var w:RolesTitleWindow = event.target as RolesTitleWindow;
                  if (w)
                        if (event.details > 0)
                        var newObj:Object = w.newObject; // new object for dataProvider!
                    PopUpManager.removePopUp(w);
                </mx:Script>
                      <mx:columns>
                      </mx:columns>
                  </mx:DataGrid>
              </mx:Canvas>
                <mx:Script>
                    <![CDATA[
                        public var newObject:Object;
                             newObject = obj;
                             closeMe(1);
                        private function closeMe(n:Number):void
                             var clsEvent:CloseEvent = new CloseEvent(CloseEvent.CLOSE, false, false, n);
                             this.dispatchEvent(clsEvent);
                </mx:Script>
                  <mx:Button x="168.5" y="127" label="Cancel" click="closeMe(-1)"/>
              </mx:TitleWindow>
              • 5. Re: problem in datagrid?
                435.mahesh Level 1
                Thaq.
                Here i have an problem with accessing dataFields(RolesDataGrid.mxml) into the
                function fnDivisionRolename(RolesTitleWindow.mxml).
                I written the code like this:
                ������������������ {���� var var_roles_datagrid:RolesDatagrid=new RolesDatagrid();
                �������������������������� var var_rolenames_employeenames:Object=new Object();
                �������������������������� //Here i have an problem with accessing datafields(col1,col2) defined in RolesTitleWindow.mxml
                plz Help me
                • 6. Re: problem in datagrid?
                  435.mahesh Level 1
                  Thanq
                  I have an problem with accessing dataFileds(RolesDataGrid.mxml) into RolesTitleWindow.mxml(fnDivisionRoleName())
                  RoleTitleWindow.mxml
                  I have written code like this:
                  �������������������� {���� var var_roles_datagrid:RolesDatagrid=new RolesDatagrid();
                  ���������������������������� var var_rolenames_employeenames:Object=new Object();
                  ���������������������������� //Here i have an problem with accessing datafields(col1,col2) defined in RolesDataGrid.mxml
                  plz Help me
                  • 7. Re: problem in datagrid?
                    435.mahesh Level 1
                    Thanq
                               {   var var_roles_datagrid:RolesDatagrid=new RolesDatagrid();
                    plz Help me
                    • 8. Re: problem in datagrid?
                      435.mahesh Level 1
                      hi natasha
                      plz help me.How to achieve that?
                      Regards
                      D.Mahesh Babu
                      • 9. Re: problem in datagrid?
                        _Natasha_ Level 4
                        sorry for delay.
                        You need to think about the design of your application if you need to do this.
                        • 10. Re: problem in datagrid?
                          _Natasha_ Level 4
                          But of you just want to solve this problem try to use this.parent
