2 Replies Latest reply on Aug 31, 2009 6:38 PM by Drew Giggity
    AMD vs Core I7 - which performs better for Adobe Products?
    Drew Giggity
      I'm currently running an AMD System (Phenom 2 x4 3.2Ghz, 8GB DDR3 PC10666, ATI 3870 512MB, Windows Ultimate 64bit, WD 120GB 10k RPM)
      and I'm wondering if it's worth purchasing and building a new, intel Core i7-920 system. I know the higher end, 970 would be better, but I don't feel like dropping $1k on a processor - so 920 is what I'm looking at.
      I would like to know (from users who have used, or are familiar with both platforms) which system performs better with the Adobe production suite and if it's worth the investment to switch from AMD to Intel. Does Hyper Threading affect the way AE / Premiere render? Will I notice a difference in speed from 8GB to 12/24GB for memory (for AE / Pr)?
      I would also like any suggestions on graphics cards (FireGL vs Quadro or GTX vs Radeon) to boost performance. I'm not much of a gamer and I would like to concentrate more of power on production. Right now I'm using a gaming card (an older one at that) and I would like to know if buying a newer one will boost performance for AE / Pr.
      Any help, tips, or suggestions would be great!
      Drew
        • 1. Re: AMD vs Core I7 - which performs better for Adobe Products?
          Adolfo Rozenfeld Adobe Employee
          I would recommend Intel processors over AMD for Adobe products.
          I can't talk for Premiere. For AE, it's perhaps marginal compared to the number of physical cores. And could be in some cases counter-productive if it tricks AE's multiprocessing system into believing there are twice as many cores, because of the way AE assigns RAM to the rendering instances it launches for each core (when "Render Multiple Frames Simultaneously" is enabled in Preferences).
          Yes, 8 GB is actually the absolute minimum you want for a quad core system (2 GB per core).
          After that, it depends on the content. For HD sized Comps, large source files and/or 32 bpc processing, having more RAM would lead to better performance and reliability.
          In AE, OpenGL previews are meant to provide a smoother/more responsive experience when interacting with the application. It won't help with render times in most cases. A medium to high end consumer level card should be fine. No need to sell the house for one of the pro level models. Keep an eye to the list of officially supported card/driver combinations.
          • 2. Re: AMD vs Core I7 - which performs better for Adobe Products?
            Drew Giggity Level 1
            Adolfo,
            Thanks for your suggestions. Sounds like a solid choice to choose Intel - as long as the memory is there.
            I also appreciate your help in furthering my understandings of how AE computes with HT and multi-cores.
            Cheers!
            Drew
