3 Replies Latest reply on Aug 31, 2009 7:40 PM by Marlene
    Flex form and PHP code
    Marlene Level 1
      I am trying to use the code from A flex Cookbook discussion called "Submitting a Flex form using PHP" The goal is to create a form in Flex and when submitted, have the form data emailed to myself. I have unfortunately spent the entire day on this so ANY HELP WOULD BE APPRECIATED. The original cookbook code is located at
      http://www.adobe.com/cfusion/communityengine/index.cfm?event=showdetails&productId=2&postI d=8523 The code (I enabled source view is at http://www.alexisjean.com/testMail.html. I get an error and never get the email. I have attached the source files in a zip and alse pasting in the code
      THE MXML CODE
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" viewSourceURL="srcview/index.html">
      <mx:Script>
      <![CDATA[
      import mx.controls.Alert;
        private function sendInfo():void{
         if(user.text=="" || email.text=="" || message.text==""){
          mx.controls.Alert.show("Sorry, information appears to be missing!")
          } else {
            svc.send()
        private function thanks(evt:Event):void{
          if (String(svc.lastResult)=="ok") mx.controls.Alert.show("Thanks! Your message has been sent.")
          else mx.controls.Alert.show("Sorry, there was a server error!")
      </mx:Script>
      <mx:HTTPService id="svc" url="mail.php" method="POST" contentType="application/x-www-form-urlencoded" resultFormat="text" result="thanks(event)">
               <mx:request>
                    <user>{user.text}</user>
                     <email>{email.text}</email>
                    <message>{message.text}</message>
                   </mx:request>
      </mx:HTTPService>
      <mx:Form>
      <mx:FormItem label="Name"> <mx:TextInput id="user"/> </mx:FormItem>
      <mx:FormItem label="Email"> <mx:TextInput id="email"/> </mx:FormItem>
      <mx:FormItem label="Message"> <mx:TextArea width="211" height="117" id="message" /> </mx:FormItem>
      <mx:FormItem> <mx:Button label="Submit" click="sendInfo()"/></mx:FormItem>
      </mx:Form>
      </mx:Application>
      THE PHP CODE
      <?php
      ini_set("SMTP","mail.alexisjean.com");
      ini_set("smtp_port","25");
      ini_set("sendmail_from", "testing@alexisjean.com");
      $email = $_POST['email'];
      $to = "testing@alexisjean.com";
      $from = "$email";
      $subject = "subject line tester";
      $msg ="Name: ".$_POST['user']."\nEmail: ".$_POST['email']."\nMessage: ".$_POST['message'])) echo "ok";
      else echo "error";
