1 Reply Latest reply on Aug 31, 2009 8:01 PM by heathrowe
    Custom colors in CS4
      Is there a way to save a custom color to use in multiple files ?  So far if I create a custom color...it seems to be saved only in the current document ?  Can you save a custom color to be used "globally" among many similar/different files ?
      Thanks, Tim
        • 1. Re: Custom colors in CS4
          heathrowe Most Valuable Participant
          To save a Library of custom Colors:
          1. Window > Swatches then from the Panel properties choose Clear Swatches
          2. Add your Custom Colors (Whatever your active Stroke/Solid Color Fill is) to the empty Swatch Panel.
          3. When you have a nice list built up, go back to the Panel properties and Save Swatches as an (.act) file.
          Then you can load up this .act file whenever you want from the same Swatches Panel property options, except choose Replace Swatches and browse to that .act collection file.
