2 Replies Latest reply on Sep 1, 2009 6:13 AM by gammajack
    Is it possible to read a var from within openedWindows?
    gammajack Level 1
      I have a public var in every <mx:Window file that I want to read while looping through open windows so I can only act on certain types of windows.
      The following code works when the curser is not focused on any specific item in the window.
      private function read_window_type():void{
           for ( var i:Number=0; i < NativeApplication.nativeApplication.openedWindows.length; i++ ){
                // breaks when focus is on something more specific
                trace(ObjectUtil.toString(NativeApplication.nativeApplication.openedWindows[i]['stage'][' focus']['descriptor']['document']['window_type']));
        • 1. Re: Is it possible to read a var from within openedWindows?
          babo_ya Level 3
          Yes it is possible.. but, I would not do this way..
          I would create an interface.. like... has X variable interface and have all window implement that interface.
          and you can treat all window as hasX variable type.
          BaBo,
          • 2. Re: Is it possible to read a var from within openedWindows?
            gammajack Level 1
            Thanks for the feedback, babo_ya.   I am going your suggested route of implementing a common interface across my windows, but I was able to extend the <mx:window> component and add a public variable to it.  I was then able to read that variable using the NativeApplication.nativeApplication.openedWindows array, but i had issues with this array because the variable was not available in the <mx:WindowedApplication> class.  I tried to extend this class, and succeeded, but I received some odd compiler errors regarding an <mx:states> implementation I had within the new custom windowed application class.
            Has anyone attempted to extend WindowedApplication with success?
