8 Replies Latest reply on Sep 1, 2009 5:29 AM by Andrew Rosewarn
    Passing array data into datagrid
    poojagupta Level 1
      I need to pass data from an Array ( of Strings) into a datagrid. I have used the following text:
      <mx:DataGrid id="dg1" x="400" y="50" dataProvider="{myArray}">
      <mx:columns>
                <mx:DataGridColumn headerText="Names" />
      </mx:columns>
      </mx:DataGrid>
      The DataGrid does not show any data as I have not mentioned the dataField. Can you please tell - what woud the dataField be in this case as the array contains simple strings.
        • 1. Re: Passing array data into datagrid
          flexprad09 Level 2
          Hi Pooja,
          Use an ArrayCollection not an Array.
          In general, you should always use ArrayCollections when binding to dataProviders of DataGrids,ADG's etc since they are property-change aware and will inform the List whenever objects are added, removed or changed within them.
          Arrays do not provide this behavior.
          Hope this link  helps you.
          http://livedocs.adobe.com/flex/3/html/help.html?content=dpcontrols_6.html
          If this post answers your question or helps, please mark it as such.
          cheers,
          Prad
          • 2. Re: Passing array data into datagrid
            Andrew Rosewarn Level 3
            Use an arrayCollection instead of an array.  If you want your array still set the arrayCollections source as your array.
            Datafield will use the string as a default for the dataField.
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" initialize="init()" >
                    <mx:Script>
                    <![CDATA[
                        import mx.collections.ArrayCollection;
                        private var myArray:Array = new Array('Andrew','Chris','John');
                        [Bindable]
                        private var ac:ArrayCollection = new ArrayCollection();
                        private function init():void {
                            ac.source = myArray;
                </mx:Script>
                <mx:DataGrid id="dg1" x="10" y="10" dataProvider="{ac}" width="184" height="165">
                    <mx:columns>
                        <mx:DataGridColumn headerText="Names"/>
                    </mx:columns>
            </mx:DataGrid>
            </mx:Application>
            Andrew
            • 3. Re: Passing array data into datagrid
              poojagupta Level 1
              Hi Prad,
              Thanks for the quick reply. But my problem still persists.
              The elements of my array (which are just simple strings) are determined at runtime. I tried using an array collection, but no change.
              I changed my code as follows.
              <mx:DataGrid id="dg1" x="400" y="50" dataProvider="{myAC}" />
              myAC is the new Array Collection.
              Any help would be great.
              • 4. Re: Passing array data into datagrid
                flexprad09 Level 2
                There is no problem in constructing arrays of strings at runtime and adding to AC [just that you need to give field name to each item of arrays].
                I am not getting your problem exactly.
                It would be better if you could boil down your code to understandable  few lines and paste.
                Cheers,
                Prad.
                • 5. Re: Passing array data into datagrid
                  poojagupta Level 1
                  Hey Prad,
                  I guess you have narrowed down the problem.
                  "How do I give a dataField name to my Array elements."
                  Thanks.
                  Pooja
                  • 6. Re: Passing array data into datagrid
                    When you come to assemble your arrayCollection with data you should create an object for each item
                    var obj:Object = new Object();
                    obj.myName = 'Andrew';
                    arrayCollection.addItem(obj);
                    Then your dataField property can call myName.  dataField="myName"
                    Andrew
                    • 7. Re: Passing array data into datagrid
                      poojagupta Level 1
                      Hey Andrew,
                      That piece of code was helpful. Now, I have started viewing some data in the datagrid. However, this data is stil incomplete...so guess i need to delve a bit more into code..
                      Thanx a lot.
                      Regards,
                      Pooja
                      • 8. Re: Passing array data into datagrid
                        Because your adding an Object to the arrayCollection you can add as many field names as you like as below.
                        <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init()">
                            <mx:Script>
                                <![CDATA[
                                    [Bindable]
                                        obj.name = 'Andrew';
                                        obj.town = 'Taunton';
                                        obj.sex = 'Male';
                                        var obj1:Object = new Object();
                                        obj1.name = 'Jane';
                                        obj1.town = 'Glastongury';
                                        obj1.sex = 'Female';
                                        ac.addItem(obj);
                                        ac.addItem(obj1);
                            </mx:Script>
                            <mx:DataGrid x="42" y="47" dataProvider="{ac}">
                                <mx:columns>
                                    <mx:DataGridColumn headerText="Name" dataField="name"/>
                                    <mx:DataGridColumn headerText="Town" dataField="town"/>
                                    <mx:DataGridColumn headerText="Sex" dataField="sex"/>
                                </mx:columns>
                            </mx:DataGrid>
                        </mx:Application>
                        In yours you just need to loop through your data source and create the objects and add them to the collection.
                        Andrew
