4 Replies Latest reply on Sep 1, 2009 7:56 AM by cfsetNewbie
    Error with query compairing form entry.
    cfsetNewbie Level 1
      Hello;
      I wrote a small log in and it is giving me a problem. I use this all the time, and can't figure out why now on a different server it's giving me a hard time.I get an error when I submit the log in form. I can't figure out what I missed and why it decided to give me a problem now.
      this is my error:
      Error Executing Database Query.
      [Macromedia][SequeLink JDBC Driver][ODBC Socket][Microsoft][ODBC Microsoft Access Driver] Too few parameters. Expected 3.
      The error occurred in C:\website\admin\LoginCheck.cfm: line 13
      Called from C:\website\admin\index.cfm: line 7
      Called from C:\website\admin\LoginCheck.cfm: line 13
      11 :  FROM adminUser
      12 :  WHERE userName =<cfqueryparam cfsqltype="cf_sql_varchar" value="#FORM.userLogin#">
      13 :  AND password =<cfqueryparam cfsqltype="cf_sql_varchar" value="#FORM.userPassword#">
      14 : </CFQUERY>
      15 :
      SQLSTATE  07002
      SQL   SELECT adminUser.id, adminUser.Fname, adminUser.Lname, adminUser.isAdminstrator, adminUser.userName, adminUser.password FROM adminUser WHERE userName = (param 1) AND password = (param 2)
      VENDORERRORCODE  -3010
      DATASOURCE  mainDB
      This is that block of code from the form to the LoginCheck.cfm block of code.
      Form:
      <cfif isDefined ("FORM.UserLogin")>
      <cfinclude template="LoginCheck.cfm">
      </cfif>
      <cfform action="#CGI.SCRIPT_NAME#?#CGI.QUERY_STRING#" method="post" name="LoginForm">
           <cfinput type="hidden" name="userLogin_required">
           <cfinput type="hidden" name="userPassword_required">
      <cfinput type="Text" name="userLogin"> <!--- there is more to these form fields, I just left it off for now to shortn the code--->
      <cfinput type="Password" name="userPassword">
      <cfinput name="Submit" value="Login" >
      </cfform>
      LoginCheck.cfm page:
      <cfparam name="FORM.userLogin" type="string">
      <cfparam name="FORM.userPassword" type="string">
      <CFQUERY NAME="IsValidLogin" datasource="#APPLICATION.dataSource#">
      SELECT adminUser.Fname, adminUser.Lname
      FROM adminUser
      </CFQUERY>
      <CFQUERY NAME="IsValidUser" datasource="#APPLICATION.dataSource#">
      FROM adminUser
      </CFQUERY>
      this IsValidUser is the one throwing the error. I have gone over this a million times and don't see what I did wrong. Can anyone see what I might be missing?
      Thank you
        • 1. Re: Error with query compairing form entry.
          Dan Bracuk Level 5
          Probably a reserved word problem, password.
          Also, your cfparam tags don't have default values and your hidden form fields don't have values.
          • 2. Re: Error with query compairing form entry.
            cfsetNewbie Level 1
            I changed the query table to Adminpass and changed my cfparam tags to this:
            <cfparam name="FORM.userLogin" type="string" default="#FORM.userLogin#">
            <cfparam name="FORM.userPassword" type="string" default="#FORM.userPassword#">
            it's still giving me the same error.
            could it be a server setting or something? This looks right to me.
            • 3. Re: Error with query compairing form entry.
              Dan Bracuk Level 5
              The default values for your cfparam tags make no sense whatsoever.  I suggest reading the manual to see what that tag actually does.
              To debug your query, take out the octothorps.  If it runs and returns zero rows, the problem is with your variables.  If you get the same error, it's with your query.
              • 4. Re: Error with query compairing form entry.
                cfsetNewbie Level 1
                I tried a number of different approaches.
                I dumped both my variables
                <cfdump var="#FORM.userPass#">
                <cfabort>
                I changed my cfparam tags:
                <cfparam name="variables.userName" type="string" default="#FORM.userLogin#">
                <cfparam name="variables.adminPass" type="string" default="#FORM.userPass#">
                I changed my query taking out the cfqueryparam tags:
                SELECT adminUser.id, adminUser.Fname, adminUser.Lname, adminUser.isAdminstrator, adminUser.userName, adminUser.adminPass
                FROM adminUser
                WHERE userName ='#FORM.userLogin#'
                AND adminPass ='#FORM.userPass#'
                </CFQUERY>
                I still get this error:
                11 :  FROM adminUser
                13 :  AND adminPass =<cfqueryparam cfsqltype="cf_sql_varchar" value="#FORM.userPass#">
                14 : </CFQUERY>
                15 :
                SQLSTATE  07002
                SQL   SELECT adminUser.id, adminUser.Fname, adminUser.Lname, adminUser.isAdminstrator, adminUser.userName, adminUser.adminPass FROM adminUser WHERE userName = (param 1) AND adminPass = (param 2)
                I'm stumped. There has to be something small missing here. It works on other servers. Why suddenly not on this one?
