3 Replies Latest reply on Sep 1, 2009 2:23 PM by babo_ya
    How to convert XML to Custom Type Object!!!!
    Phoenix_Guru
      How do we convert an XML to a custom type Value Object?
      I tried using SimpleXMLDecoder but it returns ObjectProxy not the custom type Value Object.
      Please help!!
      Guruji..
        • 1. Re: How to convert XML to Custom Type Object!!!!
          babo_ya Level 3
          Let's say you have an XML as below..
          <Employee>
               <fName>John</fName>
               <lName>Barker</lName> .... my boss's last name
          </Employee>
          then here is how u create a VO.
          create a class called Employee that has two public variable fname, lname..
          var xml:XML = .. point to the above XML..
          var employee:Employee = new Employee();
          employee.fname = xml.fName;
          employee.lname = xml.lName;
          there is your VO.
          hope this helps,
          BaBo,
          • 2. Re: How to convert XML to Custom Type Object!!!!
            Phoenix_Guru Level 1
            Thanks for the reply..
            Your solution sounds only feasible for a small XML. In my case I have the XML as a result of the Webservice. which is very very huge and complex and i can't afford to manually assign individual variable values.
            Any other ideas??
            • 3. Re: How to convert XML to Custom Type Object!!!!
              babo_ya Level 3
              Yes,
              just assign the xml to the VO and don't parse it before you need it.
              for example,
              public class Employee
                   private var xml:XML;
                   public function Employee()
                   public function parse(xml:XML):void
                        this.xml = xml;
                   public function get fname():String
                        return xml.FName;
              hope this helps,
              BaBo,
