0 Replies Latest reply on Sep 1, 2009 12:34 PM by Peter Farland
    [svn:fx-trunk] 9883: Integrating fxgutils clarifications of FXG 2.0.
    Peter Farland Level 3
      Revision: 9883
      Author:   pfarland@adobe.com
      Date:     2009-09-01 12:34:26 -0700 (Tue, 01 Sep 2009)
      Log Message:
      Changes include:
      Add check for required "href" in ParagraphNode, DivNode and TCYNode when adding LinkNode.
      DefinitionNode - match "id" attribute to a pattern.
      TextFlowAttributeGroup:
      paddingLeft, paddingRight, paddingTop, paddingBottom - changed from double to NumberInherit.
      columnGap - changed from double to NumberInherit.
      columnCount - changed from NumberAuto to NumberAutoInt.
      columnWidth - add "inherit" to NumberAuto.
      firstBaselineOffset - changed from Enum only to BaselineOffset (union of double and enum).
      verticalAlign - add "inherit" to enum.
      lineBreak - add "inherit" to enum.
      ParagraphAttributeGroup:
      textAlign, textAlignLast - change default from LEFT to START.
      TextLeafAttributeGroup:
      backgroundAlpha - changed from double to .
      ImgNode:
      width, height - changed from double to NumberPercent.
      source - remove pattern match, change it to string.
      QE notes: Yes, please update any failures from changes in FXG attributes or enums as a result of these changes.
      Doc notes: Not yet.
      Reviewer: Min
      Tests run: Checkintests, mustella spark/core/
      Is noteworthy for integration: Yes, improvements and clarifications to FXG 2.0 support.
      Bugs:
      N/A
      Modified Paths:
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGConstants.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_en.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/AbstractFXGNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/DefinitionNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/RichTextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/AbstractRich BlockTextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/AbstractRich ParagraphNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/AbstractRich TextLeafNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/DivNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/FormatNode.j ava
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/ImgNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/LinkNode.jav a
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/ParagraphNod e.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/TCYNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/AlignmentBaseli ne.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/DominantBaselin e.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/InterpolationMe thod.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/LineBreak.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/NumberAuto.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/NumberInherit.j ava
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/TextDecoration. java
      Added Paths:
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/BaselineOffset. java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/ColorWithEnum.j ava
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/NumberPercentAu to.java
